928 Forum 1978-1995
Sponsored by: 928 Specialists
My luck finally ran out (transmission)
Old 06-14-2015, 01:36 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
https://rennlist.com/forums/928-foru...t=transmission
Old 06-14-2015, 07:23 PM
granprixweiss928
granprixweiss928's Avatar
Bill
Ill host an event at my place in San Jose, where we could get a few folks together and do the swap. I have a "lift" since I think you dont any more.
My lift is a pad-lift, and goes up about 3 ft.
Speedtoys and I also will have a way to move the car as well, very soon, unlss you want to flat bed it
Let me know.
July 4 weekend would work great if you can get a replacement trans in time.
Old 06-14-2015, 09:25 PM
The Deputy
The Deputy's Avatar
I don't know if your luck ran out or not...first, it quit in your driveway...instead of hundreds of miles away...second, you have had plenty of generous offers...instead of being ignored.
You seem too "still" be a pretty lucky guy, if you ask me.
Good luck, with your repairs...and if I was closer I'd lend a hand, too.
Brian.
Old 06-15-2015, 12:18 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,451 Likes on 1,459 Posts
There's no doubt that anything metal can break at anytime, however the '89 transmissions have the later, more robust, B2 pistons. Not the very latest, greatest one, but not the "early version".
For the amount of effort required, I'd certainly encourage you to pull out the piston and take look.
You've got some great offers of help and pieces....that offer from Jerry for the '89 core is real "first class"......even if it did have a "wonky" valve body, yours would interchange.
Let me know if there is anything I can do.
Old 06-15-2015, 02:45 AM
SharkSkin
SharkSkin's Avatar
Very sorry to hear this, Bill. You must have run over a piece of Kryptonite at some point. Maybe it was a small piece and it only took out the B2 piston? Sure sounds like it's worth a look vs doing a big R&R to an unknown non-caped tranny.
Old 06-15-2015, 03:38 AM
mark kibort
mark kibort's Avatar
Let me know Bill!
Old 06-15-2015, 03:48 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Brian.
Very good points. I do consider myself still very lucky.
Old 06-15-2015, 03:56 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Again, I deeply appreciate all the generosity I'm seeing...the trannies, numerous offers of help with repair /replacement, encouragement to investigate the B2 from Greg and Dave A, Mark's (granprixweiss928) offer of a lift equipped work area and transport. Wow! I will be planning things tomorrow.
THANKS AGAIN!
Old 06-15-2015, 04:44 AM
G8RB8
G8RB8's Avatar
Sorry for your loss.
Maybe this will help.
https://rennlist.com/forums/928-foru...d-answers.html
Old 06-15-2015, 04:57 AM
FredR
FredR's Avatar
Bill,
The famous South African golfer Gary Player was often labelled as being "very lucky" when playing against the likes of Arnold Palmer and Jack Niklaus. When confronted by these allegations he infamously retorted that in fact he agreed he was very lucky- in his experience he found that the more he practiced the luckier he became!
What goes around comes around- no coincidence- given all the help you have contributed now it is time for folks to help you and great to see the offers flooding in- just shows what a great community we have here- just wish I was a bit closer so I could chip in to the effort myself.
"Chance favours the prepared mind" [Kipling].
Regards
Fred
Old 06-15-2015, 02:48 PM
RET
RET's Avatar
Bill - Happy to help too. Let me know where and when. I have a fairly good (floor type - not suitable for a lift) transmission jack if needed... and have once before experienced the fun and excitement of 928 transmission removal and replacement...
Bob
Old 06-15-2015, 03:42 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Bill--
FWIW, your symptoms coincide perfectly with those of "low transmission fluid level". Would I be out of place asking if you had looked at reservoir level?
Old 06-15-2015, 04:53 PM
karl ruiter
karl ruiter's Avatar
I would certainly check the B2 piston as I had a similar issue on my '88. In my case the piston did not break, but leaking tranny cooler lines (I think) had enabled a small amount of crud to enter the system and it built up in the B2 piston area, embedding the the seal, and eventually causing it to stick. It is so easy and cheap that you should at least have a look.
Old 06-15-2015, 05:00 PM
BC
BC's Avatar
If it wasn't interesting we wouldn't be doing it.
Old 06-15-2015, 05:58 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Thanks for that link.Lot's of good autobox info including B2.
Quick Reply: My luck finally ran out (transmission)
