928 Forum 1978-1995
Sponsored by: 928 Specialists
Found a short circuit
Old 07-03-2015, 12:29 AM
  #31
Alan
Electron Wrangler
Alan's Avatar
V 11 this relates to page "V" (roman numeral) and track# 11 - look at the numbers across the bottom (the "/" is irrelevant here and shouldn't even be there...but Porsche was sloppy).
If you trace up vertically @ track# 11 on page V you should find another tag in the same format that says VII 8 that references back to the starting page VII track# 8. These are inter-sheet connections - there is no physical connector - because these are just wires that run between these pages - they are of the same gauge and color because they are just exactly the same physical wire...
Alan
Old 07-03-2015, 11:36 AM
  #32
ltoolio
ltoolio's Avatar
Alan
So.... Joins the wire from the lamp control unit and terminates at plug K terminal 7 at the CE panel.
Quick Reply: Found a short circuit
