What was that noise?
Thanks, thats what I figured too. I will just choose to ignore the noise unless it happens again LoL
What is the deal with all the cut abs wires? How hard would that be to correct? I assume that was someones solution to a constant abs warning light or something?
Sometimes when you run over something small on the road it can be flung up and give quite a loud impact noise. Is that possible? Look carefully under the car for any new marks, dents, or other damage, which might not be suspension related. I can't see anything abnormal either.
Team Owner
usually the cut wires are from the brake sensors.
NOTE each block holds a connector for the ABS and the brake wear sensor
