928 Forum 1978-1995
Sponsored by: 928 Specialists
Cant install porken chips. :(
Old 05-25-2015, 02:18 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Default Cant install porken chips. :(
How common is a surface mounted EZK chip in a 85 32v?
Damnit...
Old 05-25-2015, 02:23 PM
PorKen
Inventor
PorKen's Avatar
Must be a very early brain. Does it have a metal MAP sensor?
I have a pile of EZ-F brains. If you don't mind reflowing the solder on the EPROM holder (common EZF problem), I sell you cheap.
Old 05-25-2015, 02:27 PM
FredR
FredR's Avatar
Didn't know LH brains had a crankcase breather!
Rgds
Fred
Old 05-25-2015, 02:28 PM
Speedtoys
Speedtoys's Avatar
No..it has the later MAP sensor.
Was REALLY looking forward to driving today..
If I can find someone around me (Im without a car today) that can work surface soldering, just swap it out?
Or..I might find my soldering iron. I found my desoldering tool from yrs ago..
Old 05-25-2015, 02:30 PM
PorKen
Inventor
PorKen's Avatar
I'm no expert, but I think it's called through-hole soldering, not surface. You'll need solder wick or a vacuum.
I would replace the old chip with an EPROM holder. You could damage the chip.
Old 05-25-2015, 02:32 PM
Lizard928
Lizard928's Avatar
Use a solder sucker. Only way to do it!
Old 05-25-2015, 02:42 PM
Speedtoys
Speedtoys's Avatar
I have the vacuum sucker, from other work a long time ago.
Considering that..I live 30min from anything, have no car, and it's a holiday.....
Old 05-25-2015, 02:54 PM
depami
depami's Avatar
If you are committed, cut the chip body from the legs + remove the legs one at a time + re-flow and suck clean the holes = minimal damage to board.
Edit:
Use appropriate cutter and direct cutting forces toward chip rather than board. You can usually lift leg out with soldering iron tip after heating. Repeat for all and re-flow one at a time. Then solder in your choice of LIF or ZIF socket.
Old 05-25-2015, 03:47 PM
Speedtoys
Speedtoys's Avatar
Taking Depami's advice, and canvasing the 'hood for a proper iron (my first attempt with the WRONG iron is apparent)..it was no problem.
IN the second photo..the most _critical_ tool, is the middle one. *hmph*
Old 05-25-2015, 04:20 PM
PorKen
Inventor
PorKen's Avatar
Chip installed in the correct direction?
Old 05-25-2015, 04:31 PM
FredR
FredR's Avatar
jeff,
You seem to be having a run of misfortune with the 928's at the moment- that looks like a sod of job.
Best wishes for a good recovery- I hate jobs like that.
Fred
Old 05-25-2015, 05:32 PM
Speedtoys
Speedtoys's Avatar
Yup.
Ran fuel system on a jumper for 10min, no leaks..button up the coolant hoses, install the ECUs...
Old 05-25-2015, 07:08 PM
Speedtoys
Speedtoys's Avatar
..and car is idling nicely.
Must be 900 parts to an S3 intake...
Old 05-25-2015, 07:23 PM
depami
depami's Avatar
Good job!
What's the airplane? Looks like it has ailerons.
Old 05-25-2015, 08:12 PM
Speedtoys
Speedtoys's Avatar
Ahh..wifes RC 182.
Needed a new controller..so she upgraaaaded it.
Quick Reply: Cant install porken chips. :(
