sunroof cable replacement, any good write ups?
i removed the sunroof and was able to see the missing cable for the PS. My first guess was correct
after removing the sunroof, i noticed i scratched the paint off. Ouch, oh well - she is going to be painted anyways.
Next dumb question:
How do i get the cable that is lost way inside the channel?
Do i rotate the transmission and then pull it out? Is the cable just pushed through the channel until it shows through the transmission spot? I did not see any locking pins for the backside, just to the plastic guide at the front side.
any help appreciated. thanks
Next dumb question:
Next dumb question:
Next dumb question:
Isn't the hole at the motor/tranny too small to pull the cable out? If it's not, you'll need to move the cable to get the end of it exposed in that hole and then pull it through.
If it is too small, I'd think you'd need to stick a fish rod into the channel tube to push the broken part out through the other end. That'll require at least pulling hte headliner back a bit.
Ok, i was able to move the cable by finger nail - one cable tooth at a time. Both of the cables are extended to the end of the sunroof now.
I can only assume the new part will come with a plastic guide connected to the cable.
I need to remove the three screws connected to the rail, till the rail up and pull the oil cable out.
I might need to read-read the write up.
Basic Sponsor
I've added this to the list of "To Do's" for our DIY tech articles. If you have any other suggestions on things you can't seem to find please let me know.
-Luccia
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Ok - ive got the sunroof repainted, new cable installed, used new drain tray, lubed and functioning.
The only problem. When closing, i need to give the sunroof a little shove up to make it lock into place.
I had this issue before, near the end of PS cable & drain tray breaking.
Note: My height adjustment screws fell out while i was sanding the roof for paint. I didnot get a chance to measure the height. I set screwed them all the way in. No adjustments, as of yet. Looks to be a good height when in position.
I noticed the guide flags on the DS was loose. I tried to align both sides plumb. My guess, this is the issue.
thoughts?
thanks jpc
thoughts?
thanks jpc
