No start - walked home
So I just walked home while my car, a 928S '84 euro, is still two streets away. I want to tow it tomorrow, unless someone has a brilliant tip about what could be wrong
I was driving a couple minutes and the engine stopped while all lights on the dashboard went on. The top center exclamation mark also blinked red.
I tried restarting it and the exclamation mark kept blinking, but stopped blinking after a couple tries. It looked all normal. However, the engine did not start.
The starter motor runs but I cannot hear the fuel pump, even if I put my ear next to it while lying behind the car (with someone else trying to start).
I tried the usual suspects. I wiggled with a turning motion all the fuses and exchanged the relays that had something to do with the fuel pump and the startup sequence. Just to be sure I also exchanged fuse 17 (fuel pump) with a new one. I also reseated the two big computer connectors in fuse box. It didn't help.
Is there a 928 oracle with infinite knowledge who can give me advice oh wise ones?
Team Owner
what was the last thing you fixed?
Jumper the fuel pump relay and see if the pump runs. If it does, try to start it. If it starts, drive home lol and then buy a new relay. If it doesn't, at least you can rule out the fuel pump and the circuit that powers it.
Were you accelerating or decelerating at the time of the incident?
I had a similar occurrence on my previous 1979 US car when it skipped a tooth on the timing belt. It is a non-interference engine so nothing drastic occurred.
/wonders why i emptied my ignore list.
You can call me Otis
Pull the tubes, and look through the holes on both cam covers, if the belt broke it would be loose on at least one of the cams, also look for belt dust. The ! light is associated with the belt tension warning system.
Supercharged
According to the owner's manual, the central warning light will only blink for the following "Priority 1" conditions:
Brake Fluid - (cannot cause a no-run issue)
Oil Pressure - (could be a culprit)
Oil Level - (also could cause be a culprit)
The manual also says the warning light will flash with the corresponding light. Do you recall which other warning light was flashing?
Team Owner
if all of the warning lights come on then the alternator has stopped charging
All the indicators are the same as if the belt broke. Flashing light caused by low oil pressure......
Please put me back on ignore. Your life will be better.
Thank you for thinking along guys! By reading about those belt issues I decided to tow it back home just in case. The 928 is back in my back yard and I will look at it when I have some free time again. Thanks again for thinking along guys, really really helpful! This will definitely put me in the right direction! I have quite a list to find the issue. I love this forum!
Little image from when it was still running
Every time my fuel pump power wire wiggled loose and the engine died, all of the dash lights came on. I don't think that's a symptom of anything other than the engine stopping and the ignition switch still being on, which would be true for a snapped belt and plenty of other things.
