FS Eibach spring set
Complete set front and rear. $300
$250
$250
What will they do to my '82? Lower? Stiffer ride?
Shawn,
Yes. Lowers the car by an inch.
Eibachs are a progressive rate spring. The first part compresses until it gets to the second part which doesn't seem to compress in comparison to the first part. It can make the car seem like it's bouncing if your shocks are not up to snuff. It also seems to me like you can feel the Waissach rear doing what it does going around corners and curves.
Takes a little getting used to when driving.
These have been long gone. I replaced them with a hypercoil setup. I do not know how it handles vs the Eibach's. With my wider tires the spring rate change was very aggressive in corners probably due to Weisach and the wider tires.
