928 Forum 1978-1995
Sponsored by: 928 Specialists
View Poll Results: How many shell set required
Just one set - throw them in, clearances should be lose enough.
0
0%
One set - mix and match to get close as possible to tolerances.
25.00%
Get several spare pairs for better matching.
0
0%
Wait until you measure the crank journals before ordering appropriate tolerance groups.
75.00%
Voters: 4. You may not vote on this poll
Big end bearing replacement
Old 04-01-2015, 08:38 PM
928Myles
928Myles's Avatar
Thanks for the comprehensive post Greg.
I am sure that the end play is at the low end of the limit - just couldn't remember waht that was (had 0.4mm in my head, probably because that was the number to worry about).
Will be nice to know how much more (if any) I have left to spend with you on your excellent products.
Myles
Quick Reply: Big end bearing replacement
