1989 Baltic Blue 928-S-4 just in
Administrator - "Tyson"
Please tell me the body is in much worse shape then the photos show......
The Parts Whisperer
Shameful Thread Killer
BTW, for anyone contemplating a low-buck repair, the bearings can be accessed from the bottom of the engine with removal of the cradle, and loosen the timing belt. as long as the crank hasn't gone into the case, it could be 'saved' albeit with some loss of utility by R&R of the main bearings in situ.
Mind you, this is not a recommendation, but know that it can be done with a lift and a few hours of gritty work. May have to replace the oil pump depending on how much bearing metal was invested.
Option codes for Baltic Blue 1989 928 S-4
BTW, that Baltic Blue '89? Here are its option codes, including its LSD
M018 M139 I158 M220 M418 M570 I586 M650 I980
18 Sport steering wheel with elevated hub 30mm
139 Adjustable Seat Heating - Left
158 Radio "Monterey" - 86 "Reno" -
220 Locking differential
418 Protective side mouldings
570 High output air conditioner
586 Lumbar support - left seat
650 Sunroof
980 Seat cover - draped leather
650 Sunroof
