Twin Midnight Blue 928 Build (91 GT- 88 S4) UPDATE II
#34
These are probably BETTER then then came out of the factory! That work is STUNNING! You should approach the president of Porsche with selling one of them since he will be getting a "factory fresh" 928. I am Speechless.
#36
Team Owner
Awesome work, so who is getting these cars?
#38
Any reason that you have deleted the pictures of your adventure from your previous posts/threads?
It was a great pictorial record of the effort you had put in.
#39
Superb looking engine bays! (altho' I prefer the regular S4 intake tubes rather than the saggy-looking GTS noise insulation)
The auto is missing the black plastic cap that goes on the end of the left-side coil
#40
Little nit picks.
The small filter for the air pump is missing for both cars.
The rubber on the fender edge on either side of the engine bay was not originally there.
The rear bumper covers are for GTS. I like the originals better.
#41
these cars are stunning by any measure. They represent the best of the best to me.
#42
#43
I did not get get your question clearly I guess. If you mean the u shaped hose below; the u shaped fuel hose between the regulator and the damper which is behind the engine, that should be stock; nothing fabricated.
We use new original P parts, if they are NLA, than we use used parts and very rarely have sth fabricated; one example is the heat shields above the last muffler protecting the battery box, pictures ı posted previously.
Please let me know what you had in mind and I will try to address it.
#44
#45
For more you can also see posted in Instagram; just search; Porsche928GT
