Notice anything unusual ('88 S4 Engine)
Archive Gatekeeper
Also has the GTS-specific notches in the sides of the girdle for rod nut clearance:
that is a rare engine... one where the dealer got the block warrantied, and switched over all the internals......somebody made some serious coin on that service....the question is... did they replace the rings... I would do a leak down test to be sure.... and a compression test too..
Hi,
Quickly jump in to this if I may,
I have a 87S4 where the previous owner changed the engine from. What came in place is a GT engine. At least as far as I know, on the flat surface next to the oil filler neck stands M28/47. But no serial number (as I understood usually stands under it) I did some searching and found out as also mentioned here that, then I could be a Porsche rebuild engine?
Then I noticed after reading this thread that if.. you have the bolts vs. studs, round breather holes in the main webs & notches in the sides of the girdle for rod nut clearance? That it’s a GTS engine “core”? so in my case a GTS block with GT internals?
Added a few pictures I made when replacing my oil pan gasket, circled in red what I think are the specific characteristics that are mentioned here?
Thanks in advance
Sander
Thanks in advance
Sander
Bleh, my 87 must have received its warranty block too early. It has nuts, not bolts, and is missing the scallops for the rod nuts.
Here's its engine number
Annoyingly, its original block was the second-last manual squirter block the factory made.. so because some previous Marquis buggered its engine, I didn't get the squirter block.
Rich
Archive Gatekeeper
And the serial number of the engine block, from the stamp pad?
Basic Site Sponsor
Basic Site Sponsor
The "excitement" of the squirter blocks always makes me smile....
Porsche didn't continue making squirter blocks past that little run, because they didn't work....they robbed too much oil from the system.
Everyone knows this, right?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
I also made a mistake - my S4 from 87 was third-from last manual car with a squirter block. The last manual squirter block engine number is stated in factory documentation - 81H00677. The docs don't provide the upper bound engine number for auto's - but IIRC the youngest auto box confirmed with squirters was Greg Nettles'. He posted pics years ago of them.
Archive Gatekeeper
My understanding is that the squirters resulted in too much oil on the bore walls, which is an ongoing problem with most of these engines especially at high rpms. The results are ring flutter, detonation, excessive blowby and crankcase pressure, oil drainage problems, etc.
If my understanding is correct, for a low rpm forced induction motor with a good ring solution (like in George Suennen's motor) and effective windage control, squirters may be a net positive. For a higher rpm motor without as good of a ring solution and ineffective windage control, they are probably a net negative.
