Possible 928 purchase
#31
Vegas, Baby!
Hi guys, been trying to make some progress with my HVAC blowing hot air all the time problem. The blue valve at the brake booster checks out fine and I couldn't find any problems with the vacuum lines or connections. I removed the vacuum manifold at the centre console and checked for leaks, it appeared there may be a leak on the White line so I fitted a new heater control valve at the fire wall. A couple of the other lines lost a little bit of pressure but very slowly and a bit stop start, not steadily like a leak? I hoped I'd sorted the problem with the new heater control valve but unfortunately not. It still blows hot even if the levers all the way to the left? At one point there was a clunk behind the centre vent area and the blowers started blowing lovely cold air but as soon as I pushed it to hot and back to cold it stayed red hot?? I was planning to check all the vacuum lines again in the morning for leaks, any other ideas I could try?
How dose the heater control valve work? Should the valve be open when the heaters on hot and closed on cold or dose it not work like that?
Please help
Ian
Please help
Ian
#32
I can't use the search function on forums to save my life!! Google finds them anyway, my main frustration is I haven't got a multimeter to trouble shoot and I've never used one so it makes it hard to find out what's working and what's not. I think I'll remove the setting motor and clean it in the morning, also I'll check the internal and external temp sensors.
Ian
Ian
#33
Ok guys, today I've made progress! When laying upside down in the RH wheel well I watched the motor that operates the flap at the end of the connecting rod was trying to move when I put the temperature slider to cold but didn't seem to be able to. I removed the motor but couldn't manualy operate the flap so I gave it a hard pull and it came free, it must have become stuck through lack of use over the last year? Once this was free I decided to open the motor and clean it.
I noticed the leg on the red component had seperated from the board so I resoldered it back into place.
The other component in the corner has over heated and burnt the board at some point, will this need replacing?
After putting this all back together it now works, but is it working correctly? When the temperature slider is at the hottest setting and moved to the cold position the motor dose not move? If I pull the lever to full cold (left as far as it will go) the motor opens the flap and the blowers go from hot to cold. If I move the lever just slightly off cold the motor returns to the original position and the blowers go hot. Is this correct or should the motor work Inbetween fully open and fully closed? I hop this makes sense!
Ian
Ian
#34
#35
Ian, while its open, replace the transistors.
https://rennlist.com/forums/928-foru...w-working.html
They're dirt cheap - should be able to get them from maplin
#37
Small update. Still battling with my HVAC system, checked the external temp sensor and managed to brake the wires to the plug on the car side! Re soldered these but still no change. Suspect a faulty temp sensor or motor. Anyway at least I've got full hot or full cold so could be worse.
Had a bad power steering leak from the two pipes coming from the bottle. I've removed both and replaced the banjo washers and jubilee clips and this seems to have stopped the drips on my drive.
I've also replaced my speedo as the cog was stripped and the mileometer and tripomiter had packed up, but now working!
Gave the engine and gearbox a good degrease and jet wash to remove years of crud ready for the new gearbox/diff oil. Then the job I'm dreading, sump gasket and motor mounts.
Are the 1995 volvo 940 motor mount the ones that will fit?
Cheers fellas
Ian
Cheers fellas
Ian
#39
Big news!
Removed the motor that controls the mixing flap and soldered in new transistors, I also resoldered all the other components on the board while I was at it. I'm very happy to report my heating is working perfectly, I now have hot and cold and everything Inbetween!
Replaced these with these
With these
I have to admit I didn't expect it to work so I'm very happy to tick this job off my list!
Ian
With these
Ian
#40
Excellent! Good feeling when you can fix things like this. I'm starting to cut my teeth on more and more electrical repairs. Sort of comes with the territory with a 928...
#42
This write-up covers it - http://members.rennlist.com/pirtle/svc_act.html
I have found and read this write up a few times as I need to look at my vac system also at some point before I waste time on major aircond components. Does this apply to pre S4 models or did the system change significantly with the 32V models.
I have a Euro S2 RHD
Cheers
#44
Hilton,
Cheers
Cheers
#45
