A Rack is not a Country but a Part on My Car
#31
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Exact same thing I did. Maybe the stop leak hasn't kicked in 100% or the seal is pretty messed up on the left side of the steering rack, well one of them.
#32
Chronic Tool Dropper
That stuff worked great stopping the seepage on the hydraulic cylinders on my MaxJax lift. It's suffered from a little bit of that since new. never enough to deserve taking the whole column apart and repairing/replacing the cylinder. Finally I decided to dd the Lucas stuff when I refilled the fluid reservoir at it's new home. Took about a week for the seepage to trail off to nothing. So no heat was involved, just time and persistence (same as 'use' on a lift it seems). Mybe a little more tim and use with yours will take care of the issue for you.
#33
Did you just add it to the reservoir or change all the fluid? Mine's about 4 gallons, how much did you use?
#34
Never occurred to me. Mine's been leaking for about a year now, same thing, just a little seepage around the cylinder seal, irritating but not worth taking the piston off and re-sealing it so I just put a towel under it.
If your lift uses hydraulic oil rather than ATF, I'm not sure this would be the perfect product. There are leak-stop hydraulic oil products but I haven't seen any as additives; they replace your current fluid. I'd be tempted to try the Lucas stuff in the hydraulic oil anyway. Our local Costco sells the leak-stop hydraulic oil in 5-gal pails in the winter, for the seasonal snowplow guys I guess.
928 Content: My lift has been used for several 928 OPG/MM projects that included dropping the steering rack.
#35
Fuse 24 Assassin
Fuse 24 Assassin
Interesting. The leak has stopped just so long as I don't turn the steering full lock left now. Great bandaid for now.
#36
Thanks for the tip. The reservoir is probably a little less than 4 gallons, I started with 5 gallons and had some leftover, that was 5 years ago though, can't remember exactly. I'll check the label, I found it on Amazon with two day shipping, might be here today maybe Monday. I'll post results. This could be a very good thing!
#37
I would be inspecting the rack boots for damage to make sure no water and or debris can get in to the ends of the rack causing further damage.
#38
Fuse 24 Assassin
Fuse 24 Assassin
I was just down there. After wiping off the fluid from the driver side boot, both appear to be very clean. The driver side has a tiny tear of about 1/8" where the ATF appears to be seeping from.
Colin, a while back in this thread someone had mentioned maybe the seal has blown out due to pressure. I'm not sure how the steering rack's main rod would have been damaged as the fluid was religiously changed since the car has been in my family since 2001. The rack is Porsche NOS and was replaced in 2004. Fluid has been changed every 5 years around the same intervals as the ATF in the transmission.
By the way, the car is still leaking fluid when it turns left, but drops, not a steady thin stream as I stated before. My driveway looks like it has the measles with all the red ATF drops though.
#39
Fuse 24 Assassin
Fuse 24 Assassin
Bumping.
My rack has officially kicked the bucket. Both boots are leaking as the seals on both sides are toast. New one on the way from 928 Intl.
For my own records, what is the wrench size to get the tie rods off from the rack?
#42
Fuse 24 Assassin
Fuse 24 Assassin
Bumping this thread from a while back.
I will begin work on replacing my leaking steering rack on Sunday since the family is sick. Looking at John Pirtle's steps, he mentions a plug that can be removed to identify if the rack is centered or not. I haven't had the chance yet to crack open the box containing my rebuilt rack to see this plug, nor have I looked at it under the car.
Could someone please send me a picture of this plug that's removable to confirm the rack is centered?
#43
Fuse 24 Assassin
Fuse 24 Assassin
Also, if anyone is viewing this who owns the WSM, could you please scan in PDF the section for Wheel Alignment for an 87-on 928 S4?
I have decided to take the car in after the procedure is done to have the alignment corrected.
Thanks!!!
Thanks!!!
#45
Fuse 24 Assassin
Fuse 24 Assassin
Perfect! Thank you. I would rather present this to the alignment guy so they have a clue on what to do (and what not to do) with the car.
