AC light out, AC compressor won't engage
This is a simple one (hopefully).
I noticed the other night my AC light did not come on with the lights. I pushed the button and noticed the AC did not engage.
Is it as simple as replacing the push switch to get it all to work?
Best wishes and merry xmas!
Received 1,543 Likes
Chronic Tool Dropper
The light on the little AC button on my car ('89) is upstream electrically from the control head relay. It has a small multi-pin plug that has no retainer, so is very (too) easily dislodged when doing stupid stuff like working on the radio and such. If you've been in the console doing anything in that area below the HVAC panel, take a few minutes to confirm that the connector behind the button is still connected.
You don't need to ask how I know about this specific 'problem'...
Very good point Dr B.
Installing a stereo head unit, if you do it 'the easy way' will often result in dislodging the connector for the AC switch.
Using the Radio Shack relay following Dwayne's tutorial is one way to go.
The other is to contact 928 Specialists for a new replacement head relay. It is an easy swap desolder/resolder job.
https://rennlist.com/forums/928-foru...trol-head.html
The Specialists relay is a replacement for the late GTS control heads IIRC. The OP's '88 is different.
Just as confirmation, I too have seen the plug come off the back of the switch. The problem is when it happens as you T/S an HVAC system issue...and you think you've broken it...as was stated earlier...ask me how I know!
Here's a question...do your fog lights work? If not, check the x-bus relay.
