Cree LED H4 Headlamps
#61
You are more than welcome anytime or I can meet you half way if you were traveling around the other end of the UK.
Steve
#63
See... this. This right here is why I asked for a decoder ring in my first post in this thread. The bulb/lens information for our cars is constantly contradicted by multiple sources. I'm sure they are all correct for some cars/configs but we need a single list of which ones are on which 928s.
Does anyone know off the top of their head? Is there an official doc anywhere that we can check for each year?
For the '87+ 928s there are two basic headlight assemblies:
- USA/Canada, DOT-approved lights with H5 (9004) bulbs, part# 928 631 135 00 MSRP $428
- ROW (rest-of-world), much better lights with H4 bulbs. These come in two flavors:
- Left-hand drive (928 631 101 03, MSRP $355 in the states)
- Right-hand drive (928 631 102 01)
The DOT-approved H5's have the three DOT-required aiming "nibs" on the face. The H4's have a flat face with "H4" embossed into the glass.
Those part numbers are the complete headlight assembles. Each can be fitted with different wattage bulbs, or aftermarket HID or LED light sources.
The optics for the H5 (USA) lights are not very good (low-beam pattern is poorly defined) and increasing brightness also increases glare to oncoming traffic. This is not a concern on a highway, but an issue on narrow country lanes.
The H4 optics are characterized by a sharp upper cutoff to minimize glare to oncoming traffic, with an extra wedge of light towards the right (or left) to light up the critters poised at the edge of the road.
Increasing brightness for the H4s has great benefit without appreciably increasing glare. Stock H4 bulbs are typically 55w, and are available in various wattages. Above stock wattage however, both heat and wiring become an increasing concern.
Which is why the new LED lights are so attractive: More light with less heat. The geometry of the light source itself is important to make the H4 optics (reflector and lens) work as intended, and the small size of the LED chip is an important part of that.
Cheers, Jim
#64
#65
I think PET is the only "official" document. But it is pretty simple.
Cheers, Jim
Cheers, Jim
Is a swap as simple as taking a H4 RH glass set up and swapping sides on the car for a LH drive application...as the beams will be directed by the pattern in the lense accordingling to the side of the road of the country they are meant for.
#66
Archive Gatekeeper
and the ROW H4 glass is very hard to come across here in the States
#67
Archive Gatekeeper
#68
It would seem simple enough to swap the assemblys from side to side so the beam is projected correctly for a LHD country. ..but nothing is ever simple is it.
I honestly do know squat about the lense bulb configurations..this thread has been a great help with what Jim posted earlier. I would like to upgrade my headlights though.
#69
Archive Gatekeeper
I'm pretty sure i can get a set of RHD H4 assemeblys pretty easily.
https://rennlist.com/forums/928-foru...-into-lhd.html
#70
Learn from the lessons of others!
#72
It most certainly is easier than HID. I converted my stock ROW '86S to Steve's Cree LED and was very pleased with the result. Then my other ROW '86S, with HID lights that I fitted a couple of years ago, lost one and I could no longer find the manufacturer. So I ripped out all the HID stuff [cost boo hoo], and fitted a second set of Cree LEDs. far superior.
#73
Thanks Jim for that very precise explanation! You boiled it down for me.
#74
I am not sure - but all things being equal they should. I will see if I can get hold of a Touareg near me to have a try and fit them. Otherwise you are welcome to try them and I will give you a refund if they do not work - just return them. However I know you are a long way away in Australia so you may prefer to see if I can try a Touareg local first.
Happy to oblige either way.
Steve
Steve
Will be in contact.
#75
Althought they may be only the 7" design for the housing, the light output, simplicity of installation, lack of wiring problems for the price is what sold me. I've run the Truck-lite for 2 years without a single problem. Playing with the wiring on a 30 year old car didn't appeal to me.
