928 Forum 1978-1995
Sponsored by: 928 Specialists
Cree LED H4 Headlamps
Old 12-20-2014, 10:11 PM
  #46
Bizman928
Former Vendor
Bizman928's Avatar
Originally Posted by uncre8tv
Thanks Steve. Where have people been mounting the driver leads? Any pic of that?
I have uploaded a video that might help explain & answer how the driver is typically mounted
Hope this helps. Feel free to hit me with any other questions and I will try my best to answer them.
Enjoy your weekend
Steve
Old 12-20-2014, 11:01 PM
  #47
Streetdaddy
Streetdaddy's Avatar
Hi,
I have a 964 with the h5 headlights, i believe. Would these bulbs work with my headlights?
Old 12-20-2014, 11:19 PM
  #48
Bizman928
Former Vendor
Bizman928's Avatar
Originally Posted by Streetdaddy
Hi,
If you have H5 headlights these bulbs would not fit as they are H4.
If there is enough interest for H5 I will see if I can get some made & get them over to Roger @ 928'sRUS
Steve
Old 12-20-2014, 11:58 PM
  #49
SeanR
SeanR's Avatar
As soon as Roger has a set of these on hand I'm putting them in my car. this should be great.
Old 12-21-2014, 12:15 AM
  #50
Streetdaddy
Steve,
I will post over on the 964 forum to garner some interest. Thanks!
Old 12-21-2014, 01:02 AM
  #51
jcorenman
jcorenman's Avatar
Originally Posted by Bizman928
If you have H5 headlights these bulbs would not fit as they are H4. ...
Steve, do you ever sleep?
Hi,
Keep in mind that the H4 headlights for 928s are the Euro/ROW configuration, US-spec cars had H5's. The difference is that the H4s have a sharp upper cutoff, and adding lumens doesn't appreciably increase glare. The US-spec H5s for the 928 spray light everywhere (I think that is a DOT requirement), and increasing brightness increases glare. One view is that is a SEP (somebody else's problem), on the other hand I like oncoming traffic to be able to see something other than my headlights.
Old 12-21-2014, 06:54 AM
  #52
neffets
neffets's Avatar
What kelvin are these H4? Have you tried them on a 80's 911, is there enough room in the back of the light housing for the fan?
Old 12-21-2014, 12:11 PM
  #53
Bizman928
Former Vendor
Bizman928's Avatar
Hi
These are 5000 Kelvin H4. We have tried these and a more compact version in the 80's 911 and whale Tale derivatives - we have a few of these in our local TIPEC region in which am joint RO. I keep working at our development team to get a solid bulb design that will fit into the 911 cavity behind the lens for the '80s cars as it will be a massive benefit for these Porsche to be able to fit our CREE LED bulbs and benefit from mower current draw but with better light to use on the road when driving.
I will kep you posted to our developments and hope to have a solid resolution early in the new year for the older 911's
Many Thanks
Steve
Old 12-21-2014, 12:19 PM
  #54
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
The bulbs are specified on the manufactures specifications sheet that these bulbs are 2800 lumen each so 5600 lumen as a set.
- it's always the simple answer that alludes me.....guess I don't do math on Friday's.
Old 12-21-2014, 04:41 PM
  #55
Wisconsin Joe
Wisconsin Joe's Avatar
Grammar either apparently.
Old 12-21-2014, 08:52 PM
  #56
bogdann
bogdann's Avatar
Offtopic slightly but will the H7's fit my 2008 Touareg RHD?
Old 12-21-2014, 11:52 PM
  #57
jeff spahn
jeff spahn's Avatar
Roger. Put me down for a full set for my H4's on my 90 S4 and both driving lights and fog lights.
Thanks,
Old 12-22-2014, 12:13 AM
  #58
uncre8tv
uncre8tv's Avatar
See... this. This right here is why I asked for a decoder ring in my first post in this thread. The bulb/lens information for our cars is constantly contradicted by multiple sources. I'm sure they are all correct for some cars/configs but we need a single list of which ones are on which 928s.
Does anyone know off the top of their head? Is there an official doc anywhere that we can check for each year?
Old 12-22-2014, 12:26 AM
  #59
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
This looks and sounds easier than what I did, stuffing HIDs into everything up front. When that ends up being a problem, I'll definitely be calling roger.
Where are you in the UK, I might like to stop by my next quarterly trip to the UK ~Jan30th
Old 12-22-2014, 09:00 AM
  #60
Bizman928
Former Vendor
Bizman928's Avatar
I am not sure - but all things being equal they should. I will see if I can get hold of a Touareg near me to have a try and fit them. Otherwise you are welcome to try them and I will give you a refund if they do not work - just return them. However I know you are a long way away in Australia so you may prefer to see if I can try a Touareg local first.
Happy to oblige either way.
Steve
Quick Reply: Cree LED H4 Headlamps
