'82 Platin Metallic 5 spd FS
Time to sell one of my 928s so I have room to work on the other in my garage. Bought this guy back in 2012, and no bones about it, she’s far from perfect. That said, she’ll be a good driver once the brakes are fixed (If I get time before it sells, I’ll be doing the repair).
Price: $4,000 until I get the brakes fixed, then $4,500. Firm.
Issues:
Sunroof- Needs cleaned and motor replaced
Interior- Needs TLC (See pics), passenger side hatch panel is a vinyl replacement. pd cracked, tear in passenger seat lower cushion.
Mech- slight grind shifting between 1st and 2nd.
HVAC- AC needs drier replaced, vacuumed, and recharged with r134, wire to compressor broken.
Electrical- rear passenger side marker occasional goes out
Brakes- pedals is soft and goes straight to floor- believed to be master cylinder
Center Console- Ashtray needs replaced.
Windshield cracked (not change in the two years I’ve owned)
Parts Included:
Porkensioner kit
Replacement HVAC drier
Work done by me:
Replacement AFM (Used)
AFM O-Ring
Scoshe Radio installed
Lizard Shifter-
New alternator
New fuel filter
New fuel line (gas tank panel)
Replacement Ignition Control Module (Used)
New Intake Boots
Replacement HVAC Head Unit (Used)
New Spark Plugs (11/13)
Temp II Sensor
O2 sensor
New Battery
Charcoal Can Y-Connector
Misc relays/fuses,bulbs, etc
Work done by PO:
water pump and timing belt -2011
Replace front chin spoiler
rebuilt steering rack
new Delrin rack bushings
new inner and outer tie rod ends
new lower ball joints
Silicon oil pan gasket with stainless steel stud set
fuel pump, fuel filter
new oil pressure sender
new belts
new coolant hoses
new fuel lines
new power steering hoses
new heater control valve
rebuilt fuel injectors
Rebuilt fuel injection wiring harness
new green wire
new thermo time sensor
new Temp II sensor
New Cat
MSDS headers
New Bilstien shocks
Distributor cap, rotor, wires
new air intake runners
Issues:
Parts Included:
Porkensioner kit
Work done by me:
AFM O-Ring
Lizard Shifter-
New alternator
New fuel filter
New Intake Boots
Temp II Sensor
O2 sensor
New Battery
Work done by PO:
new belts
new coolant hoses
new fuel lines
new green wire
new Temp II sensor
New Cat
MSDS headers
New Bilstien shocks
That's alot of 928 for the bucks... and competition optioned as well!
Might I suggest you may be selling your 928 short? However I may be completely wack on the 928 market.
That does look good for a low price.
Basic Sponsor
That is a very nice car for not a lot of money and should be snapped up.
Thanks for the kind words gents! In the end it comes down to 928, 928, wife: Pick two.
Edit: Kidding of course!
Administrator - "Tyson"
You are right re the sport seats.
First time reading that re the 3-spoke however. Curious on that one for sure... love the 3-spoke wheel!
Basic Sponsor
Front & rear spoilers were part of the Comp. package or someone had them fitted. In 82 they were only available with the Comp. package.
Yes, it is a comp package with comfort seats. As for the steering wheel, I can't speak to whether it is original. Could be a replacement if the comp came with a three spoke.
Driver's bolster pic as requested.
Porsche could have made things a lot easier if they had just added an option code to include spoilers on the US cars.
Let's face it, since the EuroS motor wasn't on the table, most US buyers only cared about the appearance of the spoiler look.
Calling an appearance upgrade "Competition Package" has sure misled a few of us over the years.
Why are you keeping the auto and selling the five speed?
If I was only able to keep one of mine, I'd keep my manual.
So just curious if there's a story behind that decision...
How many miles are on it? (didn't see that mentioned anywhere).
We're looking for an affordable manual (project) for my son...
