Performance chip 928S4 1988
#31
Basic Sponsor
OP fit an X pipe and you will get the extra kick you need - plug and play.
#32
Received 1,543 Likes
Except, of course, that his chips will be targeted at a well-running S4 with everything engine-wise working and no deferred maintenance.
I bring this up because based upon your other thread I suspect that your 928 may not be running to its normal potential?
Do you know if your resonance flap works? Knock sensors? Hall sensor? Has your mass-air sensor been rebuilt in the last 10 years? How about your fuel injectors? Have they been ultrasonically cleaned? Oxygen sensor original? Or recent? Plugs? Coil wires? Caps? Rotors? Does your 928 idle high and thus have vacuum leaks (false air)?
It's very easy for a 928 to loose 30 - 50 hp and still seem like it's running fine due to degradation of stuff bolted to the engine (or to the exhaust in the case of the 02 sensor.) There's no point in looking at chips if the engine isn't running at, or near, its original potential.
