Fuel Rail Installation HELP!
Team Owner
I would not be sanding the injector intake mounts while its installed on the engine as the sanding grit will fall directly into the cylinder thus damaging the bores
Administrator - "Tyson"
Another idea, take the injectors out of the rail and install them one by one in the intake, but lube up the o-rings first.
I too used a very slight film of motor oil, as I figured with all the oil ingestion issues on these motors how could this hurt? I found with new o-rings the injectors fit in snug but no extra force or persuasion needed. If the intake was painted I would think this slight layer would cause them not to go in. I was paranoid about dropping things in the holes after reading horror stories here, be sure to follow the advice of the pros ...
I lube up the o-rings, put in place and use a small block of wood and a tap hammer to get them in place. No harm done and been doing it that way for 8 years personally, watched the wrenches at my fathers place doing 30 years ago.
Sanding **** in to the valves? Really?
Ok, I'm stumped! The injectors will go into the holes on their own but when they are connected to the fuel rail they are too far away from the holes and they don't line up with the FPR or FPD or the lines in the front.
Is it possible that the intake mounting studs are to thick? Those in addition to the new intake gasket has the injectors a few mm to high. Any additional help would be appreciated.
I think you'll be pleasantly surprised Awilli6. My intake refresh on the S4 was my first serious foray around the engine and I was terrified I had done something irreparable. My sense of reilef was off the scale when I found the problem was just the thickness of the paint.
Agreed, that's one of the most asinine things I've seen posted here.
Gosh geeee thank youse all fer that lil' tip. Ya git learned sumthin' ever day on here.
You tossers.
Basic Sponsor
This is the difference between an 87 with rubber buffers under the rails or a later 87+ where they just bolt directly to the manifold.
I'm sorta gobsmacked that removing the manifold should need mentioning.
Even if it does mean disconnecting all that fiddly stuff underneath.
Basic Sponsor
