928 engine block dimensions
Hi guys!
New here, but have had the pleasure to surf the forum for a while.
For my project, can anyone help me with the length, width and height of the 32v engine with/without its components?
PS: I've searched but have not found it mentioned any place - so far.
Administrator - "Tyson"
I don't have one handy to measure, but the bore spacing / length is almost identical to a big block chevy. These are not small engines.
I'm almost positive they are taller / wider too due to the 32V heads.
I have a few engines in the shop, most of them taken apart except one. It is hard to measure the dimensions accurately but I find the Length to be 785mm (flywheel not included), the Width 780mm and the total Height 650mm. Note this is a German made-machine so the metric system is the only relevant but if you like the imperial dimensions divide by 25,4 for one inch.
Åke
Åke
Hi and thanks! This looks like a very good forum with high quality members and level of knowledgesharing. You are correct; my reason for asking is a chassis without any motor in it, so the measurements would help me decide on which route to go.
/K
What kind of chassis?
I've been debating on swapping the 302 Ford in my Factory Five with a 928 motor.
Thank you
Got that.
I found this picture (link below) in another forum which try to show compare a couple of engines, but no dimensions though.
http://forum.grantorinosport.org/upl...dimensions.jpg
Regards
K
Åke
Åke
Täck så mycket!
/K
Well, it was monstrous compared to the Audi v8, just from experience, bit also knowing the Audi V8 shares bore centers with the four cylinder Audi/be engine, where as the 928/944 is much larger. I think the Audi is about 100mm. The amazing thing is that, yes. The 928 should be capable of at least 8 liters with the right wet liners and a little extra stroke.
http://forums.pelicanparts.com/porsc...tre-928-a.html
Åke
