Part number please (floor mat accessory)
Please can someone let me know part number for the L-shaped bracket and latch that mounts under front seat runners, and holds down front floor mats through the reinforced hole in the mats?
I can't seem to find it in either main PET or the Seats supplement.
Basic Sponsor
I am pretty certain that the L shaped bracket was an aftermarket addition similar to the snaps that come with the Lloyds mats.
Porsche carpets were held down with a large headed plastic button that screws on the vertical post from the floor = N 900 685 01
Check out PET illustration 807-05 #2
Thanks so much Roger. That fits very well with fact that on left side there is one bracket/latch on left, but on same side on right there is no bracket, but I can see the original carpet (under mat) is held down by large button.
On the right of the vehicle there are two brackets/latches holding down mat over original carpet, and there is vertical post exactly as you describe but no button screwed onto it!
I wanted to get another bracket because the "latch" button came off post when I was cleaning carpets today, so I wanted a replacement to hold the mat down nicely (the mat has the plastic reinforced rectangular slits for the latch).
I'll take a look at the illustration you referenced. Thanks again!
Archive Gatekeeper
For posterity- never seen these listed in a factory document.
They're in the Tequipment catalogue from memory - I bought a couple of sets from Roger a few years ago using a Porsche part number.
edit: Found them in the catalogue: 000 043 202 80 listed as "set of fastening parts" for 928 on the floormats page.
Will go check in the garage as I'm working from home today - pretty sure one set is still in the box they came in
edit2: Yup, part number confirmed. I bought 2 sets of those brackets in June 2009 from Roger, price back then was $16 per set.
Basic Sponsor
Thanks Hilton & Rob - if I had a brain I would be dangerous 8>)
16 sets sitting in Germany and $21 a pair.
Do you use these when the original posts have failed/been removed/fallen off?
These brackets bolt to the seat rails, and fit metal-reinforced eyelets in original Tequipment factory floormats to stop the floor mats sliding forwards.
I can take a picture later for reference of others. It looks like the floor mats themselves are no longer produced.
