928S4 $4900 on PCA website...
No affiliation but this was passed along to me by a fellow Porsche owner. Looks to be a steal at this price as long as it is reasonably well sorted. In case anyone is the market...
https://www.pca.org/classified-ad/303846
Administrator - "Tyson"
Someone needs to check this out and see if it's just ridiculously underpriced or what's wrong with it.
this is crazy! My hand is reaching for the checkbook as I sit here. Wow!
Did anyone notice the carpet pulled away by the engine computers? Wonder if something is up there. Either way looks well priced even if it has some issues.
Someone needs to call this guy just to find out why there is a slinky hanging from the visor.
I heard back from the seller. In a nutshell per their mechanic it needs torque tube, brakes, brake booster, odometer does not work, AC does not work, leaks oil out of some seals, one power steering boot, power steering line leaking and car has been repainted and was told its "decent". The owner was quite forward and honest. I really wouldn't call this a good deal after all...
Oh and the slinky is extra... but can be included at the right price.
More details:
928 S4 Information
We purchased in April 2003 @115600 miles. The list below shows our service and repair history. The prior owner did an engine mount and power steering hose in 2001 at 109829 miles and a high-pressure power steering hose in 11/2002 at 114900 miles, right before we bought the car. We also have other receipts from the prior owner as well as a folder with prior owner records.
The odometer stopped working in 08/2011 at 126020 miles. We keep all gas receipts and used these to estimate the later mileage.
Date Mileage Items
06/2003 115800 Radiator
11/2003 116321 Major Service
New belts
New front rotors
New rear sway bar drop links
New valve cover gaskets
W/valve covers off pull rear oil galley tops and install updated plugs
Install new end cover plugs
Trans fluid change
02/2004 116783 Replace right side tie rod assembly
04/2004 117073 Replace right rear wheel bearing; oil change
01/2005 118873 Fix fuel leak at pump check valve / new crush rings
Replace transmission oil cooler line
08/2005 123819 Oil change
08/2009 124753 New catalytic converter
08/2011 126020 Speedometer stopped working
05/2012 ~128820 New water pump, replace timing belt, water pump belt, tensioner rollers, boot,
and thermostat
All 4 CV boots
Mileage estimate via fuel receipts (176.937 gal @ ~15.8 mpg = 2800 miles))
03/2014 ~130310 Mileage estimate via fuel receipts (94.211 gal @ ~15.8 mpg = 1490 miles)
Needed service items (per Chapman’s Autowerks):
Torque tube
Some engine oil leaks
Power steering bottle lines leaking
New belts
Steering boot
Maybe brakes/rotors
928 S4 Information
Date Mileage Items
New belts
New front rotors
Trans fluid change
and thermostat
All 4 CV boots
Torque tube
New belts
Steering boot
Maybe brakes/rotors
the only ones i worry about is the brakes, odo and paint.
