Help with cleaning paint
You can call me Otis
mineral spirits will do the job, not to harsh, but will soften the tape glue enough to remove. just dampen a soft cloth and let it soak in a few minutes. a little elbow grease will be reqired also.
Received 1,207 Likes
"Rapid Remover" works very well to remove glue and adhesive.
http://www.rapidtac.com/rapid-remover.html
Team Owner
PB blaster might be worth a try,
spray it on,
let it soak for 20 mins then wipe it off
spray it on,
Bila I live in New Windsor, I can help you if you want to media blast it. I could not tell what part it is. I have some black powder left, we can powder coat it if it is not to big & made from metal.
Bilal,
If it's baked into the paint (like my car), it's not coming off.
It gets into the paint itself, and then nothing's going to work.
I've checked with about six professionals now. (And tried just about everything).
If it's not gone that far, the Goo-Gone works well...
Hope yours is an easy fix.
Another good one is De-Solv-It, says it's a Citrus Solution-No harsh chemicals-100% organic for whatever that's worth...
I've used is a lot on my car to remove various sticky, or stuck on, stuff. Just used it (along with a scraper) to remove the original tape backing that holds the door molding on.
If you don't care about what happens to the finish underneath the glue, like if you're going to repaint or powdercoat it, brake cleaner spray works very well and quickly.
