Cranking long time before starting
Hi 87/S4 cranking long time before starting in morning when cold and when hot after running and up to normal temp .
battery?
Team Owner
pull the vacuum lines from the Fuel Pressure Regulator and the dampers,
smell them for fuel if you smell fuel then all 3 parts should be replaced.
To test try holding the pedal to the floor then cranking. this clears the flooding
Also run a few bottles of techron in the fuel system as well as 6oz of MMO per tank this will keep the injector cleaned and the pump working well
