Central Warning bulb question "82"
1 Post
The bulb on the console Central Warning is no longer working but the switch itself is working fine. How do I get at the bulb to replace?
Thanks... Rick
Thanks... Rick
Remove the trim around consul. There will be 2 screws (phillips) , you may also have to remove a/c (4 screws) When out disconnect and you should be able to get bulb.
VERY GENTLY pry the "H" molding out then you will see the screws holding the hvac & central controller. The "H" is very expensive, be very careful and don't bend it otherwise the brittle plastic will snap.
