928 Forum 1978-1995
Sponsored by: 928 Specialists
water on floor from a/c?
Old 08-31-2014, 07:34 PM
the flyin' scotsman
the flyin' scotsman's Avatar
Default water on floor from a/c?
pulled the GTS into the garage this aft after a spirited run and heard water dripping onto the exhaust and garage floor.
It was very humid today..........is there an issue with the a/c system? seems to cool the car ok.
Old 08-31-2014, 07:52 PM
Dave928S
Dave928S's Avatar
No ... condensate from the system inside is draining to outside where it's supposed to. On more humid days you'll find it dumps more, and is more noticeable, and with less humidity you may not even notice it.
Old 08-31-2014, 11:41 PM
the flyin' scotsman
thx Dave........makes sense only that it was dripping on the exhaust (X pipe)
Old 09-01-2014, 01:18 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
I looked at the evaporator drain plumbing on the Honda Pilot that shares garage space with the 928. With a little creative re-routing, I'll be able to get the condensate to drop onto the stainless piping instead of leaving a puddle (and subsequent water mark) on the otherwise-immaculate garage floor when I park. Just like the 928 does for me already.
Old 09-01-2014, 03:36 PM
FredR
FredR's Avatar
Malcolm,
I presume in Calgary the relative humidity is normally pretty low I suspect so high relative humidity is probably not too common- either way when rh is high you can expect plenty of condensation dribbling onto the deck via the drain pipe. If this has rotted or some of it fallen off then maybe it is not going exactly where Herman the German intended.
Nothing to worry about I would suggest.
Regards
Fred
Old 09-01-2014, 04:07 PM
the flyin' scotsman
thx Fred.........yes its typically very low RH but yesterday was not so.
It was a little nerve racking to hear the spitting of the water hitting the exhaust then look under the car to see a pool of water.
Old 09-01-2014, 04:15 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,207 Likes on 467 Posts
Malcolm,
It happened to me few times here too.
Hearing the water hitting the exhaust is a bit surprising to say the least!
Old 09-01-2014, 07:08 PM
The Forgotten On
The Forgotten On's Avatar
I recently had the drain unclog itself and dump 1/2 of a gallon of water onto the ground and made me think that the heater core croaked. I took it apart and now it is back together, for the second time .
The water dripping is a bit startling when it drips on the exhaust in traffic and you see puffs of steam. But what you are experiencing is completely normal.
Old 09-01-2014, 07:14 PM
Chalkboss
Chalkboss's Avatar
I have a functioning AC and have never seen any condensate drip. Id something plugged up? If so, where would I look? I always see the drips and puddles on other cars.
Old 09-01-2014, 08:42 PM
Bilal928S4
Bilal928S4's Avatar
If you take the air cleaner assembly off. It is on the passenger side about half way down on the firewall. If your drain is clogged water will drip very strategically on your CE panel.
Old 09-01-2014, 09:18 PM
Chalkboss
Chalkboss's Avatar
Thanks Bilal. That's is decidedly a bad place to drip.
Old 09-01-2014, 09:23 PM
Bilal928S4
Bilal928S4's Avatar
Sorry, forgot to mention the condensate drain ends in a rubber flap in the firewall that you can easily miss if you are not looking for it.
Old 09-01-2014, 09:26 PM
SeanR
SeanR's Avatar
The drain is actually above the torque tube at the front. It's a rubber tube that comes out of the floor, about 1/2 ID.
That's the drain for the under cowl area, not the A/C evaporator
Still wrong, it's a tube that runs just above the torque tube. If you have rear air, you can see the same thing back in the back of the car too.
Old 09-01-2014, 09:38 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Kiloword:
Old 09-01-2014, 09:39 PM
SeanR
SeanR's Avatar
Thanks Rob, if anyone has a picture of something, it's gonna be you.
Quick Reply: water on floor from a/c?
