Spring in seat switch
My passenger seat wasn't going forward and backward, so I took apart my switches to clean. Somehow in this process I lost the tiny spring in the middle for the pin. Anyone know where I might get a tiny spring to replace it? I really don't know where one goes to buy tiny springs. I would think anything close would work. I did successfully fix the switch for forward and backward.
Next time don't take it apart, just spray deoxit in it.
I may have some old switches and springs lying around. Will look tonight. If so pm me your address and I will drop them in the mail for ya.
I think Wally had a tip on this. When you pry open the switch, do it inside a zip lock type bag. This way you can see what you are doing and the small parts don't fly away.
Good tip from Wally, but too late now.
Maybe a flint spring from a Bic lighter?
Half the fun of this stuff is trying to re-engineer it.
http://www.drtempleman.com/coil-spri...iature-springs
http://www.acxesspring.com/small-springs.html
http://www.instructables.com/id/Make...gs-in-seconds/
This last one because I like the instruction to call the ambulance first if you use light gloves.
I got really close with the small spring inside the light up key head. Just slightly too big. Ah.
I think I removed everything fine, I just forgot there was a tiny spring in there. I put the other springs and stuff in a zip lock.
I don't know what size that spring is, so I can't really suggest a replacement.
But I can suggest trying a hobby shop that stocks slot car stuff.
I lost the spring out of my alarm switch in the door lock cylinder last winter. The local Porsche dealer could get a replacement for $10.
I found one that fit just fine and worked perfectly at a local hobby shop. It was either for a pickup shoe or the motor brush for a HO scale slot car. The clerk and I looked through a bunch of the replacement parts for a few different types of cars before we found one that looked right. 4 springs for $2.50.
I was thinking that too. Unfortunately the only local hobby shops I know of closed the last few years. Think all we have in this part of WI is Hobby Lobby now.
