928 Forum 1978-1995
Sponsored by: 928 Specialists
One of these is not like the others!
Old 07-28-2014, 03:55 PM
kmascotto
kmascotto's Avatar
Default One of these is not like the others!
So can you see the problem??...Three times I've had to flip the AC belt over, after finding it as you see in this picture...WTF. I can't believe it actually would ride on its back and stay put...
I am hoping my belt choice was the issue. I replaced all the belts when I did the WP/TB job...and I think I ordered the wrong belt (99919230550)
In 88/89 there was a change in belts for the CS/GT (637/639 codes) A/C compressor pulleys. It appears they used a narrow belt. 99919233550
I hope this will fix the issue
Old 07-28-2014, 03:58 PM
Leon Speed
Leon Speed's Avatar
Now there is something you don't see every day.
Old 07-28-2014, 04:37 PM
MainePorsche
MainePorsche's Avatar
Indeed.
That's a first.
Old 07-28-2014, 05:29 PM
Ducman82
Ducman82's Avatar
How odd! To fat and to long?
Old 07-28-2014, 06:00 PM
kmascotto
kmascotto's Avatar
Here is the belt I was using (99919230550)=Narrow V-Belt 12,5 X 1125
This is the belt I believe I need to use (99919233550)=Narrow V-Belt 12,5 X 1080
I think they are the very similar, the belt I was using is a little longer, but it was well within range of being tight.
I think it may need to be a sharper V than the belt I was using, to run in the pulley with out walking out.
Funny thing, my compressor looks different than the compressor on the GT/639 code. based on the system for adjusting the slides on the compressor, its identical to the 1989 compressor...maybe its just the pulley that's different.
Old 07-28-2014, 06:53 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,237 Likes on 1,238 Posts
I am going to go out on a limb here and say that your compressor is getting ready to fail,
the reason the belts jumping is that the compressor is locking up instantaneously ,
and then the belt of course pops off the pulley due to the sudden stoppage
Old 07-28-2014, 09:01 PM
kmascotto
kmascotto's Avatar
Thanks, what would cause the compressor to lock up?
Old 07-28-2014, 09:12 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
could be the wrong oils got mixed,
too much oil ,
not enough oil.
overpressure of a component
blocked expansion valve,
the compressor could be seizing .
IIRC Bill Ball had a similar issue a few years back cept his belt kept popping off the compressor
Old 07-28-2014, 09:27 PM
19psi
19psi's Avatar
Had that happen once on my Corvette after installing an aftermarket compressor bracket due to headers. I just needed to shim it out a bit to align the pulleys better.
My Corvair would always do that if I didn't use a wrapped belt that was adjusted just right...then again that was an odd beast in that the belt made a 90º bend from the front of the engine to the top so things needed to be perfect.
Personally, I'd make sure the pulleys are tight/aligned and toss a new belt on it.
Old 07-28-2014, 10:05 PM
kmascotto
kmascotto's Avatar
Thanks for the clarification if it happens after the new belt is installed it could be time for a compressor rebuild
Old 07-28-2014, 11:02 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
More info after some searching from Bill Ball.
https://rennlist.com/forums/928-foru...2FC+compressor
Quick Reply: One of these is not like the others!
