928 Forum 1978-1995
Sponsored by: 928 Specialists
Question re: Steering Rack Mount Bushings
Old 07-22-2014, 02:00 AM
DKWalser
DKWalser's Avatar
Default Question re: Steering Rack Mount Bushings
When I had my car aligned in February, the technician showed me that the passenger side steering rack mount bushings were starting to perish. In the last couple of months, I've noticed a slight vibration in the steering and thought it was time to replace the bushings. Here are a couple of questions:
  1. I assume that I should replace both sides at the same time. As far as I can tell, these are the original rubber bushings.
  2. Should I use original Porsche bushings or would you recommend another option, such as the delrin bushings?
Any thoughts and suggestions would be appreciated.
Old 07-22-2014, 04:07 AM
Stromius
Stromius's Avatar
Get the DELRIN replacements from 928sRUs.
Old 07-22-2014, 05:20 AM
soontobered84
soontobered84's Avatar
+1
Old 07-22-2014, 10:51 AM
Gary Knox
Gary Knox's Avatar
I fully agree on the Delrin. After having these on one car, I removed nearly new OE rubber bushings and replaced them with Delrin on the other car.
Roger Tyson at 928sRus is ready to send you a set!
Old 07-22-2014, 01:46 PM
DKWalser
DKWalser's Avatar
Default Thanks!
I appreciate everyone's input. Anyone care to explain why the delrin bushings are the better option?
Old 07-22-2014, 02:07 PM
SMTCapeCod
SMTCapeCod's Avatar
Less deformation than OEM, a little more road feel, more resistant to the fluids that usually shorten the lifespan of OEM.
Old 07-22-2014, 03:56 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,206 Likes on 467 Posts
I got a set of those somewhere in the garage since few years ago.
I need to find some time and install them.
Any "how to" on this somewhere?
Thank you.
Old 07-22-2014, 06:59 PM
Tazzieman
Tazzieman's Avatar
Hi Bertrand . I recently put solid (metal) ones in. Doing it with the rack in situ is probably "how not to".
Unless you have a hoist. Removing the old ones is a "bit tricky" , as I found out lying on my back. The new ones pop in very easily.
Old 07-22-2014, 07:09 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
I like the Delrin because they don't deteriorate with oil/heat/etc exposure as the original rubber ones do. They can be fit with a slight radial interference in the rack ears without worry about breaking the ears, vs. the aluminum with no forgiveness. The plastic will cold-flow a little as the bolts are tightened, so don't get overzealous with the wrenches when snugging these up; this is about the only reason I'd choose the aluminum over the Delrin. There are no rattles with the Delrin.
The air-chisel makes short work of the outer sleeves on the original bushings. Hand hammer and chisel is a little more work but it's just a one-time job.
Old 07-22-2014, 08:40 PM
Livio928
Livio928's Avatar
Yup. Used a Hand Hammer and large flat screw driver to get out the last bushing. The first three virtually popped out without too much work. The last one nearly killed me until I chiseled it out with a HD large screw driver. I should have kept a photo of the normal bushings that came out and the one that I defaced to get it out. I was just about to give up and switch to more drastic measures (don't ask).
Anyways, installed the Delrin bushings and waiting to get the car back on the road. Altogether, not a difficult job (final busing notwithstanding).
Old 07-22-2014, 08:48 PM
Gary Knox
Gary Knox's Avatar
One set I took out were fairly new. On those, I used a 1/8" bit and drilled out the rubber in a 360 degree area. Still pretty tight, but a bit of flame from a propane torch on the rubber to get the inner metal sleeve out, followed by a hammer/chisel for the outer sleeve with tabs worked well.
PS: I saw the later posting about using a hole saw to remove some of the rubber, so the inner bush can be removed - followed by hammer/chisel for the outer sleeve. I LIKE THAT BETTER!
Old 07-22-2014, 09:23 PM
ROG100
Basic Sponsor
ROG100's Avatar
Also the delrin bushes come in two halves - top hat shape - one half fitted from the top and the other from the bottom. This emulates the factory bushes which are one piece and require peening of the top to locate in the rack without allowing any vertical movement unlike some on the market.
Dang does that make sense!!!
Old 07-22-2014, 10:01 PM
Tazzieman
Tazzieman's Avatar
Originally Posted by Livio928
The first three virtually popped out without too much work. The last one nearly killed me until I chiseled it out with a HD large screw driver. I should have kept a photo of the normal bushings that came out and the one that I defaced to get it out. .
Don't you like how it always seems one whatever doesn't want to play ball? I kept my old ones for a day to show my sons. At least one bushing was covered in blood.
Old 07-23-2014, 12:45 AM
martinss
martinss's Avatar
I found it really easy to remove the old bushings by drilling them out thru the rubber with a hole saw and then collapsing the outer metal ring of the bushing - there was a lot of hot rubber smoke though...
Old 07-23-2014, 12:51 AM
Adamant1971
Adamant1971's Avatar
+1 on the hole saw. Just have a corded drill or more than one battery fully charged.
Quick Reply: Question re: Steering Rack Mount Bushings
