928 Forum 1978-1995
Sponsored by: 928 Specialists
Car will not start
Old 07-18-2014, 02:38 PM
provenceman
5th Gear
provenceman's Avatar
Default Car will not start
Hi All
My 87 928S4 auto will not start
Good battery
Makes a ratcheting noise but will,not turn over
Bad relay?
Any suggestions will be most appreciated
Provenceman
Old 07-18-2014, 02:43 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
How do you know it is a good battery?
Old 07-18-2014, 02:50 PM
davek9
davek9's Avatar
clean grounds and battery connection, it sounds like your describing the starter solenoid "clicking", usually a weak battery or poor connection. Could also be a bad starter/solenoid if batt and connections are good
Old 07-18-2014, 04:36 PM
provenceman
5th Gear
Hi thanks for responding Kevin
I put volt meter on the battery and it is reason 13.2 volts
Appreciate the reply
Robert
Old 07-18-2014, 04:37 PM
M. Requin
M. Requin's Avatar
Look at the ground strap, esp. the end that attaches to the car- peel back a little insulation, if you see green, replace (clean contact point as well).
Old 07-18-2014, 05:04 PM
Fogey1
Fogey1's Avatar
Good advice. A "ratcheting sound" almost always means not enough juice is getting to the starter, either from a bad battery or a bad connection somewhere.
There are a few other points in the system that can hamper the connectivity/flow of current. Battery terminals might be loose, the connection at the starter itself and the 14 pin connector come immediately to mind.
Read through the New Visitor thread
https://rennlist.com/forums/928-foru...questions.html
and look for "annual electrical maintenance."
Old 07-18-2014, 06:37 PM
Bilal928S4
Bilal928S4's Avatar
It could also be that the battery does not produce 13.2V when it is under load. Take a reading under load.
Old 07-18-2014, 07:03 PM
provenceman
5th Gear
Thanks everyone for your replys to my issue
Will try all the suggestions and get back to you all
Regards
Robert
Old 07-19-2014, 08:06 PM
provenceman
5th Gear
Just wanted to thank everyone for your kind suggestions
Turned out to be the battery after all
Even after testing the battery, it was bad
Many thanks for your support
Ground straps ok and so,was the solenoid
Regards
Robert
Old 07-19-2014, 11:11 PM
Kevin in Atlanta
Glad it was something simple.
Old 07-22-2014, 05:12 AM
Landseer
Landseer's Avatar
Don't overlook the ground strap as a secondary or parallel cause.
We've seen them reaching end of useful life, internally corroded (beneath the plastic cover).
Some manipulation of them, as when changing a battery, gives them a little more life.
With an ohm meter they appear ok, but fail in capacity to pass electrons during a start.
All of us should consider replacing the ground straps at this stage, 30+ years.
Quick Reply: Car will not start
