Supercharger help
Supercharger help
Ok
Just maybe something stupid I am overlooking
89 gt murf supercharged kit 42 lbs injectors low boost
New mass air
good vacuum
good fuel psi
air/fuel in ratio
Basically car runs well under light throttle anything over 1/2 just lays down
if I change the plug gap down to .020 from .032 the car runs pretty good and makes some power.
Tim thinks that the airflow over the maf is causing some issue.
New mass air
good vacuum
good fuel psi
air/fuel in ratio
I have heard of some airflow turbulance upsetting fuelling at idle/low loads, but nothing like you are reporting at higher loads. Certainly sounds like something blowing the spark out.....
Do you have any rubber/silicone intake tubing on the suction side that could be collapsing?
Very cool. I'm very pleased with my MURF setup. I have the intercooler too. Tons of power. Not good on tires.
Its running a little hot lately but I think my thermostat might be taking a dump. I went weeks with no issues other than setting my fans up backwards.
