928 Forum 1978-1995
Sponsored by: 928 Specialists
928srus windscreen trim is awesome!
Old 10-10-2014, 11:04 AM
  #31
Jeff928S4
Jeff928S4's Avatar
I have what I suspect is a leaking windsheild seal around the top.
In heavy rain, I will get water in the front headliner - but if I put electrical tape across the gap where the window trim meets the roof and along the front of the windsheild where it looks like Rogers kit goes, I get no leaks.
Too afraid to pull the trim and reseal the window (have read many a tutorial on trim removal and still can't figure out how to get the trim out of the clips without bending them).
Question is.....will this kit help seal the gap enough to stop water from getting by??
Old 10-10-2014, 06:19 PM
  #32
jetson8859
jetson8859's Avatar
Roger, how about throwing a few sets in the back of the car for 3rd Coast!? Can pick up, install and test out the difference on the drive from ATL and back!
Old 10-11-2014, 01:56 PM
  #33
ROG100
Basic Sponsor
ROG100's Avatar
I will do - maybe win one as a door prize 8>)
Old 10-30-2014, 04:43 PM
  #34
jwillman
jwillman's Avatar
I have a set and finishing up some paint touch up before reinstalling the trim.
I can't tell from the pics at the beginning of the thread.
Does the trim extend around the top under the trim for a bit?
I assume the concave curve edge faces out.
Old 10-30-2014, 04:44 PM
  #35
jwillman
jwillman's Avatar
dup post
Old 10-30-2014, 04:47 PM
  #36
SeanR
SeanR's Avatar
You can cut it and trim it however you want to. Curve it on around if you so wish.
Old 01-15-2019, 09:09 PM
  #37
merchauser
merchauser's Avatar
BUMP these bits sound great. would love to see some better photos. is it easier to install when replacing windshield?
Old 01-16-2019, 01:08 AM
  #38
The Forgotten On
The Forgotten On's Avatar
Sadly Roger stopped selling the strips when a few people's windshields cracked.
I recommend getting the Porsche sealing strips and GTS trim. The trim is cheap, the seals... Not so much.
Old 01-16-2019, 08:14 AM
  #39
merchauser
merchauser's Avatar
not familiar with the difference in the later sealing strips and trim. can you expand? thanks
Old 01-16-2019, 08:42 AM
  #40
linderpat
linderpat's Avatar
Received 2,246 Likes on 1,253 Posts
interesting. I had not heard that. What/how happened?
Old 01-16-2019, 11:13 AM
  #41
dimi5928
dimi5928's Avatar
I am interested too, the windshield is out and i am thinking to put them on when i install it.
__________
Dimitri 88 s4 BB
Old 01-16-2019, 01:12 PM
  #42
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
The stock piece is a soft compliant rubber.
The replacement is not...a windshield is never the same height off the body as another car, so the space that sits in, changes.
Hard plastic on the glass stressed it on tighter cars.
Old 01-16-2019, 02:01 PM
  #43
polecat702
Vegas, Baby!
polecat702's Avatar
I was thinking about buying a set of these for my 89. Jim Corenman, told me that the gap at the top of the windshield corner trim allowed rain water to exit there and you could lower the door windows without water coming into the car. Later models with the rubber trim, wouldn't do that. He has cars with and without the rubber seals, lives in Washington State where it rains a lot, so I believe him.
Old 01-17-2019, 10:37 AM
  #44
ROG100
Basic Sponsor
ROG100's Avatar
I stopped selling them because of potential fitting issues. The seal is soft rubber and the same shore hardness as the original GTS seal. The cross section of the seal is an identical copy of the Porsche 91 to 95 seal. The seal requires careful installation on pre 91 cars due to the gap being different including the trim clips.
The trim needs to be a tight fit for obvious reasons. This requires the trim to be pushed into the slot. In doing so too much pressure can be exerted and the older more brittle glass can crack. It did so in a couple of installations. Because of this I withdrew the seals from the market.
Probably sold about 50 sets and have them fitted to 3 of my own cars. Better to be prudent than see expensive windshields being broken.
Old 01-17-2019, 10:43 AM
  #45
ROG100
Basic Sponsor
ROG100's Avatar
I am sorry Jeff but that is not correct - you may be thinking of another plastic filler piece. My seals were exact copies of the cross section of the 91 to 95 seals and the exact same shore hardness - I had one tested to ensure the match.
Quick Reply: 928srus windscreen trim is awesome!
