Instrument Pod Crack Repair
Like most every 928 around, my S4 (despite the entire interior being in amazing condition..) had the usual cracked dash pod. Options, as we know, are a leather or vinyl cover from Champagne or Budd, or the Just Dashes formed cover.
I located a company called Fibrenew who repairs vinyl and leather goods. Chris Page here in Tidewater was directed to me, and as it turns out, he is a car guy working on a Mercury Cougar. Good start.
Chris spent a bunch of time on the crack in my pod. I checked-in on him periodically to see how he was doing; frankly, I was quite surprised as I thought it would involve just squirting some compound into the crack and going from there. Not even close. It was far more involved.
For final finishing, he brought the pod to his shop and returned it today. Amazing! Crack is gone, the vinyl is refinished, and all for a fraction of the cost of a leather cover. Couldn't be more pleased with the outcome.
To contact Chris, give him a ring at 757-630-2389 or via tidewater@fibrenew.com.
Archive Gatekeeper
Great looking repair, I don't recall ever seeing such a nice result! I suspect he's going to be busy for a while......
Per Chris, it's a permanent repair and seeing the repair, I believe it.
The process involves drilling holes down each side of the crack and injecting the repair compound into the holes and under the vinyl covering to tie all of it together rather than just fill the crack. Sanding, redying and texturing are the final steps.
Other 'kits' will have you believe that filling the crack will effect a repair and now seeing how it's really done, I'd be suspect of anything other than the Fibrenew approach.
A really nice guy, too.
You can't judge much until its seen the heat and sun a bit. The original vinyl shrank and split at the weakest point. That weakest point has now been reinforced, next split at the second weakest point. I hope it holds up, but it would be the first of this type of repair to do so.
