928 Forum 1978-1995
Sponsored by: 928 Specialists
Static Spring Rates
Old 03-06-2014, 04:25 PM
77tony
77tony's Avatar
Default Static Spring Rates
Looking for static spring rates for earlier "S" type cars that I believe have the green markings. We have springs at the shop that are marked brown and believe are off of the 79. OEM for the 79 are: front: 215 lbs./inch and rear: 120 lbs./inch. TIA. T
Old 03-06-2014, 07:09 PM
FLYVMO
FLYVMO's Avatar
Tony,
WSM page 40-46 (Suspension volume) has the spring rates for brown markings. Depending on how many brown dots you have it varies from 6375 N - 6570 N for one dot, to 6767 N - 6963 N for three dots. Compressed distance is 191mm at that force. Spring length should be 340 mm uncompressed for new springs with brown markings. So if I understand it correctly, it takes 6375 N to compress the spring 191 mm. Now you just have to convert that to lb/inches
Here is one link: http://www.leespring.com/tolerance1.asp
Another: http://people.physics.anu.edu.au/~am..._conversio.htm
And one more: http://www.proshocks.com/calcs/coilsprate.htm
Cheers!
Carl
Old 03-07-2014, 11:54 AM
Carl Fausett
Developer
Carl Fausett's Avatar
That's really good information, Carl
Years ago, I took a set of stock 1982 non-S springs to a shop that had a spring measuring stand to measure their spring rate. We brought them down into the center of their range and they measured 215 lb/ft in the front and 120 lb/ft in the rear. I always thought that low, but that's what the machine said.
Later, we had a customer who wanted just to replace his springs with stock spring rates. He just wanted new springs of OEM stiffness. When we used these numbers, the curb height stood too low and the suspension was very soft. We fitted others, and arrived at 300 lb/fronts and 200 lb/ft rears to get a very stock-like look and feel. This is likely just a small bit stiffer than OEM for that year/model.
I have since installed several sets of these, and the results are repeatable. For this year/model, 300 lb/ft fronts and 200 lb/ft rears produce a setup very close to stock.
I hope this info is useful for you.
Old 03-07-2014, 12:28 PM
FLYVMO
FLYVMO's Avatar
Thanks Carl,
Doing the math with above links, I come up with a spring rate of about 208 lb/inch for the front. Can't find any info for the rear springs. It is low, but close to what you measured. I wonder how much "spring rate" the lower A-arm rubber bushings add to the package?
Was that customer using springs of the exact same length or shorter springs with same rate?
Cheers!
Carl
Old 03-07-2014, 05:47 PM
Carl Fausett
Developer
It was one of our Hypercoil/Koni shock setups that he wanted to emulate stock springs. That means we would have been using an 8" tall spring in the front and a 12" tall spring in the rear. Like this:
Old 03-08-2014, 05:54 PM
77tony
77tony's Avatar
Thanks for the info Carl & Carl. Used the pro shocks link Carl (FLYVMO) provided above for the following calculations. Here is how the front spring rates fared. OEM wire diameter.574, Weltmeister .622, both spring diameters were the same at 5.12, and both have 6 active spring coils. OEM free length: 350mm, Weltmeister: 260mm ! So it looks like if one coil were removed, the OEM spring rate would be 324.9 and if 1.5 coils were removed the OEM spring rate would be 361.0. T
Old 03-08-2014, 06:39 PM
FLYVMO
FLYVMO's Avatar
Awesome Tony!
You're a real math wizard! Good info, thanks for posting it. Let me know how the cutting works out with the front adjustment issue.
Edit: With same calculator, stock spring rate comes out to 270...higher than I thought, and higher than measured by Carl earlier.
Cheers!
Carl
Old 03-08-2014, 09:07 PM
77tony
77tony's Avatar
Originally Posted by FLYVMO
Awesome Tony!
Cheers!
Carl
Sounds like that's the solution, cut off 1.5 springs to get a comparable spring rate of 361.0 to match up better with the 385.4 Weltmeisters that are coming out. This should get us matched up for what's needed. This OEM spring should compress slightly more to due to the slightly thinner wire. Hopefully this formula will let the front end settle to a ride height that can will be in the mid-range for adjustment purposes. JP is approx 150lbs less up front with the LS motor/serpentine system and with only 10lbs added in toward the rear with the addition of the just slightly heavier Z06 six speed. T
Old 08-12-2014, 10:34 PM
z driver 88t
z driver 88t's Avatar
Tony - doing some research and digging into understanding coil / spring calculations. You mentioned 6 active coils in your formula. Are you sure it would not be 7 coils? Based on this link I think you count the final (i.e the top or bottom, not both) coil as well as the internal coils. http://springipedia.com/compression-counting-coils.asp
Old 08-13-2014, 12:04 AM
77tony
77tony's Avatar
Chris, Maybe either Carl could chime in here. T
Old 08-13-2014, 12:39 AM
GlenL
GlenL's Avatar
Going back a bit...
The springs are rated at the total force at a compressed height. You can't work back from these numbers as it doesn't say how much it was compressed to get here. The figures say it's applying roughly 1500 pounds when compressed to 8 inches. This helps set even spring heights which is especially important for the non-adjustable fronts on OBs.
To the last post:
Springs aren't "bending" and much as the wire is twisting. It's not real important, but I think it's interesting. Halps to figure out what shortening the coils does. Reduce it by X percent and it's 1/X percent stiffer. For example, if you cut off 50% (1/2) then it's 200% (2x) stiffer. Math is fun.
So... If you cut 1.5 coils off a 7 coil spring it'll be 27% stiffer. That makes a 300 lb/in spring a 381. If it was supporting an 8" spring supporting 900 pounds, the old compressed height was 5" and the new height is 3.1".
Old 08-13-2014, 07:12 AM
UpFixenDerPorsche
UpFixenDerPorsche's Avatar
The pic shows a 'closed' spring. The flat coil at each end does not contribute to the rate and are inactive.
928 springs are 'open' coil. This allows every coil to be active. Means U can do more with the spring in limited space.
By cutting off a coil you will actually increase the spring rate since the total shorter length of wire will have to twist more per inch of suspension travel.
Leave everything as is. In everyday driving you wont notice the difference.
Cheers.
Upfixen.
1990 GT. 1000lb/in fronts. 800lb/in rear. Revalved Konis.
Old 08-13-2014, 10:42 AM
FLYVMO
FLYVMO's Avatar
Originally Posted by GlenL
Going back a bit...
To the last post:
Maybe my math is a bit rusty, but we know the spring is 340 mm uncompressed, we know the N it takes to compress the spring 191 mm. Since it is a linear spring rate, would we not be able to work that out? Example, using the higher force spring (6963 N), converting it to 1565 lbs to compress 7.52 inches. Comes out to 208 lbs/inch. (Compare that to the measured force of 215 lb/inch as measured by Carl. Pretty close) Am I doing it incorrectly?
Cheers!
Carl
Old 08-13-2014, 11:59 AM
GlenL
GlenL's Avatar
The problem is that Porsche doesn't spec the free length, only the compressed height and force. If you're sure the free length is X and it has force F compressed to Y then the rate is F/(X-Y). Porsche specs the springs as "F at Y."
Old 08-13-2014, 12:25 PM
FLYVMO
FLYVMO's Avatar
Hi Glen
Maybe I am misunderstanding the shop manuals then, but they do list the free lengths, see below, rightmost column:
This makes me come up with either 208 or 267 lb/inches depending on how you interpret L1. If L1=length of entire spring when compressed then it is 208 lb/inches. If L1=distance compressed then 267 lb/inches. I did guesstimate that it was the first number since it corresponds closely to what has been measured. Although I can't tell for sure what spring the test was done on.
Cheers!
Carl
Quick Reply: Static Spring Rates
