Rotor directionality
I've just received a new set of Zimmerman front rotors for my '85 and they have slots. The PET calls out two different numbers for L & R and the boxes are marked that way, but I understood the difference was in slot direction. Turns out these rotors are symmetric, so if I mount them with the slots striking the outer edge of the pads first on the left side, they strike the inner edge on the right.
I've gotten conflicting reports on this. Brembo says the slots must always strike the outer edge of the pads first, Centric has an article that claims you can't tell the directionality of the rotor by looking at the slot, instead you need to look at the vanes.
Anyone out there feel like advancing a deciding vote?
Chronic Tool Dropper
Look at the vanes first. Their orientation is much more important than the slots. The vanes should have outside end trailing inside end, if that makes sense. So with the rotor spinning in the direction of the car going forward, air is drawn in the middle and spit out the outer ends. IMHO, keeping the rotor cool with proper airflow is the priority when choosing which side the rotor goes on.
The slots are there (supposedly) to allow gasses generated during hard braking to vent rather than build a boundary layer that might reduce the pad contact with the rotor. They are not directionally sensitive for that purpose.
If you stick a pencil into the vanes on the top of the rotor, the pencil should point towards the rear of the car.
Team Owner
take a peek at where the cooling air enters the center of the hub,
air in the center and out at the edges
Thanks everyone, that confirms what I'd hoped. To summarize:
- The vanes are most important and should be oriented to spin air out at the edge, not pick it up. This directs heat away from the center of the rotor.
- It really doesn't matter how the slots are oriented.
Thanks.
By "inner" I meant the smaller part of the circle made by the rotor, the part of the pad that's closest to the hub. "Outer" refers to the part of the rotor with maximum circumference, the "outside" diameter of the rotor. I actually stole those terms from an ad for Brembro slotted rotors that describes how to orient them during installation. Thankfully, we have Dr. Bob, who appears to know what he's talking about I'll try harder next time...
Mine too. That was exactly what I thought at first; it was designed to scoop air into the rotor rather than throw it out. Until Bob (and Stan) explained it it never occurred to me that I was thinking backwards. It's funny when that happens, a sort of "well DUH!" moment
It makes sense you'd design it to move heat away from the center of the rotor and, most importantly, the wheel bearings. Sometimes I'm still amazed by the simplicity and elegance I find in the design of these systems.
Captain Obvious
Super User
Super User
On a street driven car you will not notice a difference if the rotors are on backwads. It's good to install them tbe proper direction but it's not that big of a deal if the car isn't tracked.
