Someone here removed oil cooler line fitting and piece of block came with it
I know for damn sure someone here took off one of the male oil cooler line fittings in the block, and a little piece of the block, the machined seat where the fitting seals came off with it. Does anyone remember this thread? Same exact thing happened to me. What did the guy end up doing?
I think the factory used some sort of loctite to install those. You are supposed to heat the area up until the loctite melts away and then try to undo them.
I would put everything back together with gasket maker. Victor Reinz or Honda bond.
