928 Forum 1978-1995
Sponsored by: 928 Specialists
EXPERTS please chime in: how much to torque hose clamps?
Old 11-16-2013, 10:44 PM
syoo8
syoo8's Avatar
Default EXPERTS please chime in: how much to torque hose clamps?
I'm buttoning up my intake and coolant hoses.
How much should I torque the worm-drive hose clamps? I don't want to tighten too little and allow a leak, but not too tight and risk ripping something.
Searching the internet, I've found disparate responses:
a) "7 lb-ft."
b) "22 inch-pounds"
c) "Tighten until the clamp does not move, then add two turns."
What do the experts say?
Old 11-16-2013, 11:18 PM
James Bailey
James Bailey's Avatar
Much depends on how old are the hoses and what type and how old the hose clamps. But remember coolant system pressure is limited by the radiator cap to ONLY about 14 psi... it really should not take much
Old 11-16-2013, 11:32 PM
GlenL
GlenL's Avatar
Experts?
It's surprising that there aren't clearer specs on this. The answer will vary depending on what type of hose and clamp are being used.
A problem is that over-tightening the clamp will damage the hose or the clamp. But you don't want a leak. What side to err on? I tighten as tight as I can using a screwdriver or nut driver. A wrench gives a lot more leverage and makes it easy to be too tight. I go easy if using a wrench, or socket wrench, and would think the toque is about 2 ft lbs. So I'll go with answer "b."
A related note is that Porsche always uses good hose clamps with rolled edges and raised threads. Some go down to a fixed size and eliminate the question of what toque entirely; just make them close.
Old 11-17-2013, 12:23 AM
17prospective buyer
17prospective buyer's Avatar
Lol, i like how you emphasize EXPERTS!! One thing to think about is getting those spring steel type that always apply the correct pressure (and a bitch to get off without hose clamp pliers). I'm sure Greg will correct us all here in a minute or two.
Old 11-17-2013, 12:46 AM
syoo8
syoo8's Avatar
Originally Posted by GlenL
Experts?
A wrench gives a lot more leverage and makes it easy to be too tight. I go easy if using a wrench, or socket wrench, and would think the torque is about 2 ft lbs. So I'll go with answer "b."
2 ft-lbs sounds really low to me...
Old 11-17-2013, 01:53 AM
uncre8tv
uncre8tv's Avatar
Yeah, go with a nice tight 24in lbs instead.
Old 11-17-2013, 04:11 AM
NoVector
NoVector's Avatar
Where do you buy quality hose clamps? I hate the cheap ones that break as soon as the slightest torque is applied. Grainger, Fastenal?? I have a box of good and bad that I've collected over the years--but I never know 'til I use it. I'd like to throw them all away and start over.
Old 11-17-2013, 03:06 PM
17prospective buyer
I would imagine a good fastener place sells them, or a performance shop. Lol the buckwheat quote made me laugh, we had a co-op student at the dealership that we called Buckwheat. Dumber than a bag of hammers, useless kid.
Old 11-17-2013, 04:10 PM
GlenL
GlenL's Avatar
Originally Posted by NoVector
Where do you buy quality hose clamps? .
I got a sales kit of Norma clamps off eBay a few years back for about $50. Checking now, they want a pile of money ($150) for the same thing. Google for Norma clamps and you'll find a bunch.
Old 11-17-2013, 04:17 PM
NoVector
NoVector's Avatar
^^^^ Perfect, thank you! Just looked, also on Amazon
Edit: I also see on one of the e-bay ads "Original Equipment on Porsche, BMW, Audi, Land Rover, Jaguar, VW, Corvette and many others."
Old 11-17-2013, 04:54 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Interesting, the torque values are _really_ low.
From
https://www.belmetric.com/metric-cla...esrrcv4rl7tkh0
Code:
Part #	Range 	Width	Torque	Torque	Torque
	(mm)	(mm)	in-lb	Nm	Ft lbs
CR12	8-12	9	22	2.5	1.83
CR12N	8-12	7.5	17.7	2	1.48
CR16	8-16	9	22	2.5	1.83
CR16N	8-16	7.5	17.7	2	1.48
CR20	12-20	9	26.5	3	2.21
CR22	12-22	9	26.5	3	2.21
CR27	16-27	9	26.5	3	2.21
CR32	20-32	9	26.5	3	2.21
CR40	25-40	9	26.5	3	2.21
CR40W	25-40	12	26.5	3	2.21
CR45	30-45	9	26.5	3	2.21
CR50	32-50	9	26.5	3	2.21
CR60	40-60	9	26.5	3	2.21
CR70	50-70	9	26.5	3	2.21
CR80	60-80	9	26.5	3	2.21
CR90	70-90	9	26.5	3	2.21
CR100	80-100	9	26.5	3	2.21
CR110	90-110	9	26.5	3	2.21
CR120	100-120	9	26.5	3	2.21
CR130	110-130	9	26.5	3	2.21
Old 11-17-2013, 05:01 PM
James Bailey
Yes like I said it should not take much
Old 11-17-2013, 05:30 PM
depami
depami's Avatar
http://www.ebay.com/itm/Free-Ship-75...-/140902415847
Old 11-17-2013, 05:59 PM
syoo8
syoo8's Avatar
From
Code:
Ok. I stand corrected! Looks like 2 ft-lbs it is!
Old 11-17-2013, 11:30 PM
sendarius
sendarius's Avatar
How much to torque hose clamps?
I'll do it for a dollar - plus travel expenses.
Quick Reply: EXPERTS please chime in: how much to torque hose clamps?
