928 Forum 1978-1995
Sponsored by: 928 Specialists
V12 6spd 928
Old 10-25-2013, 10:31 AM
  #46
123quattro
123quattro's Avatar
Can you swap in Supra cams?
Old 10-25-2013, 11:26 AM
  #47
txhokie4life
txhokie4life's Avatar
Originally Posted by FBIII
Is the Toyota going to hopefully sound like a Ferrari?
2012 Ferrari 599XX Evoluzione PURE SOUND & Glowing Brakes - YouTube
Those auto-blips make me jealous -- I can barely heel toe and its more like
ball/side of foot - toe.
But the engine sure does sound neat.
Mike
Old 10-25-2013, 12:32 PM
  #48
xschop
xschop's Avatar
I spoke with Brandon and he said the ACT T023 heavy duty pressure plate has held up to 500 HP on a few of his known 1uz swaps with the billet steel flywheel.... It's surface is 9.375" OD and 5.875" ID
http://www.summitracing.com/parts/ac...ta/model/camry
It matches the FW PP pattern of the custom 1uz/1gz Flywheel...
http://www.1uzfeswapkit.com/Flywheel...-0000-0008.htm
Old 10-25-2013, 01:39 PM
  #49
xschop
xschop's Avatar
You'll need this.....
And I'll modify the 944-uz/gz adapter by removing TT locating spud and tapping for C5 Torque tube pattern....
Old 10-25-2013, 08:17 PM
  #50
The Fixer
The Fixer's Avatar
Originally Posted by Dinsdale Piranha
Jaguar! I'm crazy, not suicidal. Besides the motor is already on the way. ETA next wed.
Sounds very cool Dinsdale, Good luck with it.
Jaguar V12 is a great motor though, good (strong) for racing.
Can make big HP. People are starting to realize how good it is.
Did you consider a BMW V12?, they are a dime a dozen over here (BMW 750i parts cars available everywhere), it's German, it's bullet proof, and it was used in the original 243 mph McLaren F1. (627 BHP with modification of course)
That motor won LeMans and many other major race venues in that car.
BTW in Europe there are Guys running boosted BMW V12s (M70) with stock bottom ends putting out 1000hp
and staying together just fine. That would give Tony a run.
Old 10-25-2013, 09:06 PM
  #51
Flint Ironstag
Flint Ironstag's Avatar
Default This is gonna be epic...
... Jag V12 gets a bad rap. Just like any semi-exotic, the weak points are well documented, and preventive maintenance and upgrades will make it quite reliable. Definitely staying tuned to this thread. V12 928 = win
Old 10-25-2013, 11:06 PM
  #52
The Forgotten On
The Forgotten On's Avatar
So you are building a 928+4? Sounds like fun
Old 10-26-2013, 04:25 PM
  #53
IcemanG17
IcemanG17's Avatar
Originally Posted by Speedtoys
Bout 310Hp@5200, and..the fun part..300FtLb starting at 1200, peaking 355 at 4100 IIRC.
Wow quite the stump puller.....odd really since most V12's seem to be more midrange motors.....
Old 10-26-2013, 06:13 PM
  #54
FBIII
FBIII's Avatar
Except the Italians.
Old 10-26-2013, 06:14 PM
  #55
69gaugeman
69gaugeman's Avatar
Subscribed.
Old 10-26-2013, 07:48 PM
  #56
123quattro
123quattro's Avatar
I think the biggest downside to the Jag V12 is pulling the entire intake manifold to change plugs. It's non-trivial.
BMW V12 are plentiful, but they are a lot less reliable than the BMW V8s.
I think it's a cool choice. It's hard to beat Toyota when you are looking for something reliable. And at 450 lbs I bet it's quite a bit lighter than Jag and BMW engines.
Old 10-26-2013, 08:08 PM
  #57
The Fixer
The Fixer's Avatar
I owned a 750i and my Father in Law has one.
They are bullet proof, fuel efficient (even the old ones) and it takes all day to change the plugs.
Old 10-27-2013, 08:11 PM
  #58
dzaprev
dzaprev's Avatar
You must have a lot of time on your hands.....keep us posted
Old 10-27-2013, 09:25 PM
  #59
Dinsdale Piranha
Dinsdale Piranha's Avatar
Time? I lost my watch years ago. Calendar also.
I am doin what I said I wanna do when I grow up............build fast cars.
Old 10-27-2013, 09:26 PM
  #60
alabbasi
alabbasi's Avatar
The plugs are hard to change on HE motors. For the non HE cars, they're pretty easy. V12 jaguars are pretty reliable if you stay on top of the fuel system and make sure all the hoses are in good order and the ignition system is in good order. Else they will be prone to catching fire. Other then that, they have the usual Jaguar electrical problems. But if you own a 928, this should not be anything that you can't handle.
Quick Reply: V12 6spd 928
