928 Forum 1978-1995
Sponsored by: 928 Specialists
Alternator pulley fan...bent...question
Old 09-19-2013, 11:34 AM
Five-8
Five-8's Avatar
Default Alternator pulley fan...bent...question
Hi All
In the process of swapping out my alternator, pulley fan has a nasty bend in it. Should i try and straighten this back or just leave well enough alone, meaning will straightening it fatigue the metal?
Seems like it should straighten out without issue, but wanted to check with you folks who know way more than i do.
Thanks as always
Cheers,
Old 09-19-2013, 11:44 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,253 Likes on 1,247 Posts
Turn that fan over, place on a solid work surface,
with a mallet and piece of hardwood work the bend.
Start at the edges of the bend and move to the edge of the fan,
you should be able to reform the fan.
Make it look as flat as possible,
and make sure the rear fan blades dont touch the alternator housing
Old 09-19-2013, 11:48 AM
Five-8
Five-8's Avatar
Thanks for your response Stan, much appreciated!
UPDATE;This worked a treat, not quite perfect but pretty darn close!
Cheers,
Old 09-19-2013, 12:02 PM
Alan
Electron Wrangler
Alan's Avatar
Its not really under any stress there anyway - so as Stan says - straighten away... It won't take much and doesn't have to be perfect to be much better
Alan
Old 09-19-2013, 12:04 PM
Five-8
Five-8's Avatar
Thanks Alan, all seems to be good.
Cheers,
Quick Reply: Alternator pulley fan...bent...question
