928 Forum 1978-1995
Sponsored by: 928 Specialists
85 928 no start
Old 09-12-2013, 04:30 PM
jtischner
6th Gear
jtischner's Avatar
Default 85 928 no start
I recently had the S300 chips installed with a new 87 fuel regulator and x-pipe exhaust. After picking up car from the shop, the car was having starting problems. that is, it wouldn't start on the first turn of the key. Once started the car drove normally. The last time the car started it struggled again, but finally did start. Drove it home, parked it for a week or so, tried to restart and nogo.
Engine turns, but no spark.
Things we've tried/repaired:
1) Fuel pressure is good - after changing burned fuse for the fuel pump
2) Changed relays IV, XIV, XVI - no spark
3) Check spark plugs - no spark
What else can I check ?
Note: The car had no starting problems at all prior to the S300 chips being installed.
Thanks.
Joe Tischner
Old 09-14-2013, 05:59 AM
Randy V
Randy V's Avatar
You'll have better luck posting this in the 928 forum instead of the Posting Guidelines forum.
Old 09-19-2013, 08:32 PM
Randy V
Randy V's Avatar
Maybe not.
Old 09-19-2013, 08:40 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
this was a duplicate double post the other one has been answered
Quick Reply: 85 928 no start
