GTS Windshield Side Seals $38 a pair
#31
#35
The 90 GT Jarrod and I both owned did NOT have these. However, after complaining about the wind noise at high speeds my mechanic told me about the ones that came on the GTS. He ordered and installed the factory ones and it helped.
#36
Basic Sponsor
Picture out of the car?
#39
Gerry's are made from a hard ABS type plastic that flexes and does not seal anything but look good. I currently have one of his on my car as the other blew out on the highway. These replicate the factory rubber ones that fit snug and seal as they should as good as the factory ones.
#40
Shameful Thread Killer
Hi Roger, add a set to my order that is currently with you. I will email you separately.I am certain we had discussed a set of the original Porsche and they were expeeeeeeensive!. Cheers
#44
Do these seals have the triangle section that fills the section between the rain gutter and the outside of the windscreen trim. It is this small section that made the biggest difference when trying to eliminate wind noise. I went from nothing on my 90 to Jerry's solution and then to the porsche GTS seal. The porsche GTS seal was the best by a long way, but then it was the most expensive solution.
