Windshield wipers park.
Hi
Without any apparent reason, my windshield wipers started to park slightly out of place, a little high on the windshield, as you can see in the pic.
They work perfectly, at any speed and also in the intermittent position, so from what I've read the relay is ok.
It seems that when the intermittent relay is bad they park wherever they feel like but also the intermittent speed doesn’t work, and that is not my case.
With the wipers up and the car running to make sure they have the correct energy from the battery, I’ve tried to “cycle” them several times, in all speeds and also in the intermittent speed.
Is there any simple adjustment that can be made on the wipers themselves or the wipers arms to put them just a little bit down?
Regards
Regards
