928 Forum 1978-1995
Sponsored by: 928 Specialists
Replating fasteners/small components
Old 09-10-2014, 12:36 PM
  #46
dr bob
Chronic Tool Dropper
dr bob's Avatar
Pretty parts! Good tip on the acid-wash for stripping the old plating off.
My original recommendation still stands though-- get a protective clear-coat layer over the yellow zinc. The chromate layer, the 'yellow' zinc, and the base zinc layer itself, are quickly turned to gray (less than a year) in anything short of that perfect dry climate. These plating layers are sacrificial by design, reacting with contaminants so that the base steel part does not.
Old 09-10-2014, 12:48 PM
  #47
IXLR8
IXLR8's Avatar
I did order a couple of cans of 2K high-temp gloss clear for some aluminum parts that I am glass beading. That is a two-part industrial finish that is supposedly very durable.
The original yellow zinc held up pretty well for its age so I will leave the newly yellow zinc plated parts as they are.
Old 08-01-2015, 02:58 PM
  #48
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,541 Likes on 1,228 Posts
I took a bit of a field trip with about 130 lbs of pieces to Burbank plating, to see whether they would in fact be willing to do real yellow cad plating for a civilian who just shows up on their doorstep. Turns out the answer is yes- They did it in two batches, all the small pieces get barrel plated, and all the bigger ones get hung on a hook- the finish ended up being ever so slightly less 'gold' on the hardware, and a bit less shiny than than the hose ends and fuel rails. Total cost was $300, for whatever that's worth. Turnaround time was 10 days.
90 lbs of hardware, unsorted.
6 hours (...) later:
Patient wife:
Here's a natural light shot showing the diff between yellow cad (left) and yellow zinc (right). I think the cad is going to look a whole lot closer to the mildly faded pale gold matte patina that one sees on original low mileage cars. There's still too much chromate variation of the surface but I think that will fade a bit with a couple of heat cycles.
Pretty suspension bits for an early car:
Old 08-01-2015, 06:41 PM
  #49
Leon Speed
Leon Speed's Avatar
Good result for an OCD-saturday! I'm a bit surprised cad plating is still legal in Californa.
Old 08-01-2015, 07:07 PM
  #50
Rob Edwards
Archive Gatekeeper
I was too, but Burbank plating has been there more than 40 years, so they must be grandfathered in. I was pleasantly surprised that they were willing to do it, figured I'd need some sort of document stating I was building an SR-71 replica or something, but no.
Old 08-01-2015, 07:37 PM
  #51
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,197 Likes on 466 Posts
Nice!
Love to see shinny parts like that.
Rob, what your wife thinks about laying down all these parts everywhere on kitchen counters?
Old 08-01-2015, 07:39 PM
  #52
Rob Edwards
Archive Gatekeeper
Who gives a ****?
She's very patient with it, though it's all still sitting there as I had a bunch of stuff to do in the office today. At least she knows exactly where I am on Friday night.....
Old 08-01-2015, 07:44 PM
  #53
Leon Speed
Leon Speed's Avatar
She's probably away for the weekend
Old 08-01-2015, 08:21 PM
  #54
Eplebnista
Eplebnista's Avatar
None of the commercial platers in my area will touch any lot that small. Nice looking stuff, i am most jealous.
Old 08-01-2015, 08:25 PM
  #55
Rob Edwards
Archive Gatekeeper
Their minimum batch is $200, I 'm sure people mail them stuff all the time. No downside to calling them.
Old 08-02-2015, 12:15 AM
  #56
Ducman82
Ducman82's Avatar
im shocked you have to sorted and organized the boxes of shiny parts behind Gregs work benches... :-)
Old 08-02-2015, 12:39 AM
  #57
Rob Edwards
Archive Gatekeeper
And all of the cupcake tins of shiny bits, organized in order of their appearance on the PET pages? Where do you think I learned my 928 OCD from?
Old 08-02-2015, 03:31 AM
  #58
NoVector
NoVector's Avatar
Hi Rob - Just curious if you applied a clearcoat to your parts(?) I did when I did my top-end refresh a couple months ago and I noticed it kinda washed out the "bling". I'm more than okay with that--especially if it helps it last. Just curious if you did/noticed the same thing or if it was just a chem reaction specific to the plating kit I used. You can kind of see what I mean in these pictures.
Old 08-02-2015, 05:39 AM
  #59
stuartbrs
stuartbrs's Avatar
Here in Tasmania there is nowhere that does quality Zinc plating. I sent some stuff up to a place in the North of the state and it came back and I was deeply unhappy with the finish.
I have used the Janes kit with good results on my 911 race car build.
http://forums.pelicanparts.com/porsc...ml#post8207933
I also tried some zinc plating by using a cheap bath of Vinegar and Epson salts and got great results.
http://forums.pelicanparts.com/porsc...ml#post8568578
The next car I build though, i think I would like to try Nickel Plating.
Old 08-02-2015, 11:26 AM
  #60
Ducman82
Ducman82's Avatar
he he he.... i know right!
Quick Reply: Replating fasteners/small components
