Oil Level Sender
Oil Level Sender
Hi folks, I was about to reassemble my Oil Pan with the new Silicone Gasket when I saw a wire that seems to be disconnected inside the Pan for the Oil Level Sender.
I removed the three bolts that support the Sender to the Oil Pan and cannot remove it to see what is wrong.
How do I remove the Sender from the Oil Pan? Is there any trick?
Any idea if this wire can be reattached, or do I need a new Sender?
Appreciate the help.
Ducman / Gaugeman
Just hit with a Rubber Hammer....came out. Thanks. I guess at times I am just too cautious with her.
The wire is disconnected from under the sender. I'll try to solder it back there.
Re-soldered it in place, tested and seems to be working beautifully
Now tomorrow I will continue my saga: finalize Oil Pan and then the (in)famous Motor Mounts
Thanks guys
Thanks guys
