Dual Auxilary Power Mod
So I didnt like how the power outlet was underneath the ash tray door. It was ackward and didnt like the look either. Then if you have to plug your phone in and something else like a fuzz buster for a road trip your screwed. So heres my solution.
Electron Wrangler
For a manual car that is still a challenging location due to the shifter throw - esp for the bigger charger adapters...
I like the passenger side of the console better - but having dual outlets is nice - a couple of USB charger ports would be nice too... these days that covers most of what gets plugged in...
Alan
Alan
My S4's don't have rear AC, and I've got an extra clock surround where a PO had an alarm LED by the clock where the AC controls are - my plan is to drill a 19mm hole and flush mount one of these chargers there on the passenger side of the clock, wiring it to the cigarette lighter (I'll remove the tangs and pin and wire some pigtails directly to the internals of it).
I'm also going to mod the charger so it charges android devices at full speed - In stock form, most ebay chargers are 2A capable, but use iphone/ipad charging signalling so will only fast-charge apple devices.
I put a pigtail where the amp used to be. flop it out when we need it for a trip with an inverter, hide it otherwise. I like that USB nubbin solution, though. How are you going to get it to get out the amps to charge bigger devices? my blackberry won't charge on most cheapo ebay setups.
Electron Wrangler
Or you could go with one of these (admittedly significantly more expensive solutions):
http://www.ebay.com/itm/Blue-Sea-Dua...cbb603&vxp=mtr
I do already have one on the way (from last week) so this thread is timely - I also have the Blue Sea outlets - so it matches. Its about 10X the $ of the Chinese plug ins - but it panel mounts, has blade connectors, a cover and is a very good brand - I have many Blue Sea marine items - they are all excellent quality - so I have high hopes...
I may also use the sill cover where the amp was for this.
Alan
Alan
You can make the modification either to the port itself, or to a USB cable - I prefer to do the port, so I don't have to worry about family members plugging the wrong cable into a PC and blowing the USB power circuit (i.e. phone tries to suck 2A out of a 500mA PC usb port).
"Apple" charging ports (i.e. most ebay ones) provide differential voltage on the data pins - so to make the mod for android devices, I just remove the SMD resistors to cut the power to the data pins, and then bridge them.
I just bought some of these dual-usb chargers.
"dad...my IPAD is broken..it wont charge"
