928 Forum 1978-1995
Sponsored by: 928 Specialists
New Oil Product
Old 02-21-2013, 10:21 AM
Bilal928S4
Bilal928S4's Avatar
Default Hemmings Motor Oil
Just saw this on the hemmings website.
http://www.hemmings.com/classicoil/
Does anybody have any experience with it?
Do not want to start a "mine is better than yours" thread.
Old 02-21-2013, 12:19 PM
AirtekHVAC
AirtekHVAC's Avatar
I wonder who makes it for them...about 9$/qt.
Old 10-23-2014, 10:22 AM
Bilal928S4
Bilal928S4's Avatar
Default Another engine oil thread
I was reading Hemmings and it seems that they have developed zinc rich oil for older cars.
http://blog.hemmings.com/index.php/2...rs/?refer=news
Anybody have experience with this oil?
Old 10-23-2014, 11:39 AM
Dan87951
Dan87951's Avatar
I have never used that oil but I have had excellent luck with Shell Rotella 5w-40 (good zinc content) diesel oil in my car. I run it in one of my daily 928's for 40k miles so far and when I had the valve covers off last the camshafts still looked great with no noticeable accelerated wear. I think that speaks volumes.
forgot to add:
I had two oil analysis done when using this oil and they both came back great. If I remember right there was a petroleum engineer on this forum (Doug?) that owned a 928 who did a series of tests and also recommended this oil.
Old 10-23-2014, 12:27 PM
andy-gts
andy-gts's Avatar
I have heard so many people say not to use oil made for diesel engines in the gas engine due to too much detergents or too strong detergents that I have always shyed away from them. use what the manual calls for .....nothing more or less and you will be safe.....
0.02
Old 10-23-2014, 12:43 PM
Dan87951
Dan87951's Avatar
0.02
Interesting...because Shell Rotella T6 5W40 meets API SM specifications (oil for gasoline engines).
Old 10-23-2014, 12:54 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
Shell Rotella T6 5w40 and Mobil 5w-40 Turbo Diesel Truck are unique diesel oils that are also rated for gasoline engines.
I use the Mobil 5w-40 in my gas cars that call for that weight.
Old 10-23-2014, 05:48 PM
UpFixenDerPorsche
UpFixenDerPorsche's Avatar
forgot to add:
The analysis numbers are all that matter.
Old 10-24-2014, 09:51 AM
Petza914
Petza914's Avatar
Received 6,139 Likes on 3,912 Posts
I too use Mobil 1 Synthetic Turbo Diesel 5W-40 in my 6.0 L gas engine GMC Sierra Pickup, my 5.6L gas Infinit QX56 and was using it in both my 997 C2S 3.8L cars (because of the high Phosporous & ZDDP content). Based on some intput from other 997 Forum members and Jake Raby at Flat-6 in GA, I've changed those 2 cars over to Motul X-cess 8100. Never had any issues with the Mobil 1 in them though, even at 220 F still shows 5 bar on the gauge at anything above idle. Those guys concern with the M1 TD truck oil was it's sheer properties at high RPMs since diesel engines run at much lower RPMs so I still use it in my truck and SUV as they rarely see more than 4,000-4,500 RPMs.
In both my '74 914 and my Indmar Marine Engine, I use Mobil 1 15W-50 (used to use the Extended Performance version but they don't make that one anymore).
In my SC 928, baased on the advice of Carl at 928MS, I'll be running a conventional oil or partial synthetic as he says some of the internal seals need a petroleum based oil to remain swolen and seal well, whereas, when exposed to a full synthetic, the seals shrink and then you get leaks. Anyone have any recommendations on a really good conventional or partial synthetic for this application?
Old 10-24-2014, 09:56 AM
Dan87951
Dan87951's Avatar
Agree!! The best part is this oil readily available from Wal-Mart and is reasonably priced!
Old 10-25-2014, 04:17 AM
UpFixenDerPorsche
Originally Posted by mark kibort
but i think the zink .
It's "zinc", Mark.
Bit of a giveaway I think.
Quick Reply: New Oil Product
