928 Forum 1978-1995
Sponsored by: 928 Specialists
Baking calipers with seals/boots installed-who's done it?
Old 10-20-2012, 04:18 PM
ammonman
ammonman's Avatar
Default Baking calipers with seals/boots installed-who's done it?
I painted my calipers day before yesterday with VHT caliper paint. I still need to paint the Porsche lettering and then clear coat them. If I don't bake them @ +200F for 30 minutes per the directions I must wait 7 days before adding any additional coats of paint.
Does anyone have personal experience with baking calipers with the seals and dust boots installed and the baking not affecting them? I have seen a few posts that argue that brakes get much hotter during use, etc., etc. but haven't found anyone who said they actually did the baking with no ill effects.
All input appreciated.
Mike
Old 10-20-2012, 06:15 PM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
No personal experience, but 200 degrees F. does not sound very hot compared to pictures I have seen of glowing red-hot brakes in night racing.
Good luck,
Dave
Old 10-20-2012, 06:19 PM
Ducman82
Ducman82's Avatar
i did it, used VHT caliper paint. worked just fine
Richter12x2
Richter12x2's Avatar
Well, the seals would be dry in the oven though, with no fluid to act as a heat sink. 200 degrees seems like it would be fine though.
I guess the most telling thing, is if it's official brake caliper paint, and VHT tells you to bake them, and doesn't tell you that all the seals should be replaced, then it's probably fine or else they'd open themselves up for lawsuits.
I used the POR15 brand of paint myself, and it didn't ask to be baked.
Old 10-20-2012, 07:49 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,206 Likes on 467 Posts
When I did mine, I removed the pistons. Put them in the oven for 1 hour or so at 300F if I remember well.
200F isn't very high so don't see any problem.
Old 10-20-2012, 09:50 PM
ammonman
ammonman's Avatar
Thanks guys. I'll bake them out tomorrow.
Mike
Old 10-21-2012, 10:43 AM
GlenL
GlenL's Avatar
If it were me...and it's not...I'd pull the boots and seals and then replace them. That way there'd be no fluid in the calibers to spoil the painting and baking and there'd be fresh seals and boots on re-install.
I will grant that getting the pistons in with new seals and boots is a bit tricky. The parts are cheap, though, so having an extra kit on-hand isn't a problem.
Quick Reply: Baking calipers with seals/boots installed-who's done it?
