928 Forum 1978-1995
Sponsored by: 928 Specialists
Hall Sensor and Crank Position Sensor Harness
Old 04-11-2016, 11:11 AM
  #31
blazing928
blazing928's Avatar
MPvIII is a ***** to get to, not sure why they had to bury earths under other components, as if a few cm would make that much difference.
And yes, don't mix up CPS wires.....been there .....hmmm
Old 04-11-2016, 02:17 PM
  #32
Taguid
Taguid's Avatar
I have a 91 S4 and my CPS is marked with BG on a yellow band on the wire.
Old 01-09-2017, 08:28 PM
  #33
BC
BC's Avatar
Originally Posted by Kevin in Atlanta
So, since I am replacing the male hall sensor connector I believe looking at the male connector in the same orientation (single up and double down) the wiring is the opposite. Given that as you look at the male connector the order of the wires is left to right is Red, Green, Black.
Can anyone confirm this information is correct?
Old 01-10-2017, 12:35 PM
  #34
dr bob
Chronic Tool Dropper
dr bob's Avatar
BC --
I don't have my original sensor close enough to verify. But....
IIRC, The ground (shield) terminal should not have any continuity to the other two pins. That leaves the polarity/direction of the other two a guess. But at least the shield wire should be obvious by meter resistance test.
Old 01-10-2017, 01:27 PM
  #35
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Couple of orientation pics here, post #21:
https://rennlist.com/forums/928-foru...ing-wiait.html
Quick Reply: Hall Sensor and Crank Position Sensor Harness
