Leaking Injector(s) how to test?
I think that by using the fuel pressure guage on the passenger rail (remember temporary is recommended now), you should see pressure remain fairly constant for say at least 30 minutes after running and turning off. Mine disapated after a short few minutes thus confirming a need for new injectors. I did rule out the dampers and FPR first though.
Rest in Peace
Well to add to the list ...
Fuel Pressure Gauge bounces when the injector/injectors fire by about 5-7 psi.
You lean the car out and then pull your CAT and look up the manifolds.
My fuel pressure regulators where shot and have been replaced.
If the fuel pressure is dropping, I guess also the check valve could be broken. Or you have a leak somewhere. It won't help you to test the injectors I guess.
Why not pull them, put compressed air on the inlet and stick the outlet in a cup of water?
Rest in Peace
I failed smog for a second time even worse than the first. time.
