Rear Wheel Bearing
#31
Who knew they made a nut cracker. I thought my wife had that title. Just kidding.
I bought one. I'm glad you posted that. I had no idea how to remove that nut. I'll try it later today and put everything back together. Hopefully it stops the noise from the rear wheel.
#32
Under the Lift
If you have stripped threads, you'll need a new shaft and/or nut(s). You are not going to find those at the local hardware store. If the threads are not stripped, you don't need a nutcracker - you just need two wrenches as Wally described.
#35
No Mas!
I've taken the wheel, brakes and rotor off about 4 times in the last 2 weeks. Ordered the hub pin and put it in today. I still get the horrible grinding/rubbing noise when I hit brakes.
It must be the result of a missing circlip. I had the Indy press the old bearing out and the new one in. I know I didn't put a circlip back in. I guess they left it out. I'm going to take it to the shop.
#36
Watching wheeler dealer. Doing rear wheel bearing on an Audi. When I started watching, he was removing the circlip. I picked the wrong week to stop sniffing glue...
928, audi, bearing, berkeley, brake, california, disassemble, freely, indy, parking, rear, repairs, replacement, service986forumcom, spin, wheel
